hp 15-cx0006ur battery counterfeit check error
  • Dwitty
    • Jul 2021
    • 21
    • Earth
    After replacing the battery, a message appears at startup: battery counterfeit check error.
    Is it possible to modify the bios to remove this message?
    https://ftp.ext.hp.com/pub/softpaq/s...0/sp143814.exe
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Genghis_Khan
    ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
    by Genghis_Khan
    I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
    Issue summary:
    Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
    However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
    11-11-2025, 11:51 AM
  • drscoot
    HP X360 convertible battery blown fuse error, not charging
    by drscoot
    HP Modelnumber: 14-dh0061nb​
    This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
    The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
    I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
    And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
    All these 3 batteries are charging...
    12-15-2023, 05:54 AM
  • ianbak
    Dell Vostro 3578 Battery Error
    by ianbak
    Please can anyone shed some light on why my Dell Vostro 3578 is giving the following BIOS error: 'The primary battery is not identifiable and this system will not charge this battery pack.'?
    The problem is not the battery - I've tried three different identical ones, all Dell OEM. They all work perfectly in other systems (different models, though) whilst giving the same error in the Vostro.
    The laptop will run happily from the battery if it is charged and Windows accurately reports the charge level, proving that the communication between the laptop and the battery...
    10-17-2025, 02:52 AM
  • mkdj
    by mkdj
    Mark and model: ASUS X571
    Tests already made:
    - I have removed...
    07-14-2025, 09:16 AM
