GL4A5/GL5A5 NM-C741 Buffer size not equal to IC size CH341A
  • kings cross
    • Jan 2023
    • 17
    • Israel
    Im trying to program a bios chip and I get this error
    The bios (even the original) is 16MB but the chip is only 10MB
    Any solution?
  • mon2
    • Dec 2019
    • 14551
    Re: Buffer size not equal to IC size
    No flash chip will be 10MB in size. The flash chips are always with a density of power of 2.
    That is, 2..4..8..16..32..64..128..256..512..etc.
    Post the full markings on the flash IC and the tools you are using for the reading / writing. Very likely that your programmer software is faulty.
    • kings cross
      • Jan 2023
      • 17
      • Israel
      The chip is Gigadevice J2041 25Q80CWIG
      I'm useing CH431 programmer and i tried with neoproggramer, asprogrammer, CH341 programmer and same result.
      Reading the original file from the chip was 16MB also
      • kings cross
        • Jan 2023
        • 17
        • Israel
        I can see in colibri the chip is 1MBx8
        but still the bios I was read was also 16MB so I really confused
        What should I do now? i can't even write the original file back
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3616
          • slovakia
          this is not main bios chip
          • mon2
            • Dec 2019
            • 14551
            Can you share more details of your logic board / make / model / silk screen?
            The GD flash you have shared is 1MBx8 = 8 megabits in density.
            If your BIOS file is larger, then you are referencing the wrong flash memory device on your logic board. It is very possible to have assorted flash memory devices onboard.
            Often, there is a low density flash near the KBC / EC controller and that may be the one you have removed (1MBx8).
            The higher density flash device that is the main bios is still somewhere else onboard.
            • kings cross
              • Jan 2023
              • 17
              • Israel
              It's a Lenovo L15
              Board: GL4A5/GL5A5 NM-C741 REV 1.0
              This chip is connected to the bios battery so i thought this is the bios chip
              But when i read from it the file i got was 16MB as well so any way even if it's not the bios chip i can't write the original file back
                • 21465
                Is that what is etched onto the top of the chip or are you using the Auto-detect to read the chip and its what is shown in the software screen.
                • kings cross
                  • Jan 2023
                  • 17
                  • Israel
                  That's what wrighted on the chip
                    • 21465
                    Did you disconnect the CMOS battery and the main battery before reading the chip.
                    Did you use Auto-detect or choose the chip manually.The auto-detect setting can often read the wrong size chip.Choosing it manually is always the recommended way for the CH341A, also the EZP programmers, they can mess up as well.
                    You didn`t try writing to or erase the chip did you ? ,if not then the chips contents should still be there and you can go searching for the proper bios chip.
                    Another thing i should mention,if you have the black PCB CH341A version there is a voltage modification that can be done to make it more reliable,its an easyish mod that only involves lifting one leg of the CH341 IC and soldering a wire from it to a voltage regulator
                    Heres some videos
                    https://www.youtube.com/watch?v=-ln3VIZKKaE
                    https://www.youtube.com/watch?v=HwnzzF645hA
                    • kings cross
                      • Jan 2023
                      • 17
                      • Israel
                      Heres some videos
                      I soldered the chip on the adapter board, and i selected the chip manually.
                      The chip is 10MB in every single software i tried even without the programmer pluged, so it's not the software and probably not the chip
                      I just don't understand how the reading was 16 if the chip is 10.
                      and what in the name of god is the actual bios chip?
                        • 21465
                        The chip isn`t 10 as already said by @mon2 ,it is 8Mb megabits (lower case b is bits and upper case B is Bytes),so the file read should be 1,024KB which is 1MB MegaBytes
                        Post pictures of the adapter board without the chip on it and the software screen when the chip is read manually.Also post some of the 10MB and 16MB backups you made.
                        Can you answer the other question i asked, did you erase the chip or try writing to it ?
                        • kings cross
                          • Jan 2023
                          • 17
                          • Israel
                          Sorry i didn't noticed you asked
                          i earased the chip after i read it and then tried to write and noticed somthing is wrong
                          i posted here the only beckup i have from this chip
                          i really appreciate your help bty
                          • R_J
                            • 9581
                            Here is the datasheet
                            • mon2
                              • Dec 2019
                              • 14551
                              Memory org
                                • 21465
                                Well,the mystery continues. The backup you posted does look like a full 16MB backup,but there`s no way on earth that you read that from the 25Q80CWIG chip, no way.Are you sure you havn`t got confused, you been drinking
                                EDIT: found this while searching the forum for a GL4A5/GL5A5 NM-C741 bios https://www.badcaps.net/forum/showpo...7&postcount=10 .Now that explains what i think youve done.You backed up the bios from the real sized chip, (bios dump at post #13) ,then youve tried to flash a bios to a different chip (the 25Q80CWIG chip) and erased it.So at least youve got a full sized bios backup. Flash the file posted by Volinkas (#6) to the 25Q80CWIG https://www.badcaps.net/forum/showthread.php?p=1203957
                                • kings cross
                                  • Jan 2023
                                  • 17
                                  • Israel
                                  i'm pretty sure
                                  i already erased another chip without reading by accident so i was really careful this time
                                  But thats exactly the mystery i'm taking about
                                  I also tried comparing this file with all the bios files I have for this laptop and none of them matched so i extreamly confused
                                  • kings cross
                                    • Jan 2023
                                    • 17
                                    • Israel
                                    I just can't understand what is wrong with this laptop
                                    It's seems to be on, the cpu is getting warm, and there's a nice melody for the diagnostic android app which says 'internal BUS error' but i can't see anything wrong with the voltage or resistance. then i found on lenovo forum someone who posted there's few pcs of this model with the same problom coused by BIOS update and i thought it's probably the problem with my laptop
                                      • 21465
                                      i'm pretty sure
                                      See post #16 ,i made a few edits.
                                      • kings cross
                                        • Jan 2023
                                        • 17
                                        • Israel
                                        This was the first accident i was talking about
                                        But now it's another chip
                                        Because I wasn't sure which one was really the bios chip, so I thought if the bios has a battery it should be connected to the bios chip
                                        I guess i was wrong but now what?
                                        there's no hope for this laptop?
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • sarah1331
                                          Lenovo L14 GL4A5/GL5A5 Superviser passowrd Help please
                                          by sarah1331
                                          can anoe help me please i have tried the lenovo auto patcher but it doest work
                                          i have dumped two chips
                                          mxic MX25U12872F
                                          GigaDevice 25Q80CSIG
                                          (Attached)
                                          i have located another (not read yet) winbond 25Q80DVIG
                                          L14 GL4A5/GL5A5
                                          serial number PF-30HVJJ
                                          MANY THANKS
                                          Paul
                                          01-18-2025, 08:31 AM
                                        • cicos
                                          GL4A5/GL5A5 NM-C741 Schematic
                                          by cicos
                                          Does anyone have a LENOVO schematic
                                          MB : 20U7-0002GE
                                          MAIN : GL4A5/GL5A5 NM-C741 Rev:1.0
                                          CPU : AMD RYZEN 5
                                          There is a difference in the 20V power supply from the scheme posted here.
                                          VBR
                                          08-03-2023, 03:00 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • Yanleb
                                          Schematic or datasheet for Plasma TV buffer chip
                                          by Yanleb
                                          I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                                          So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                                          Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                                          05-18-2022, 01:36 PM
