Gigabyte GA-EVEMLK RAZOR BLADE RZ09-00830
  • Daudi83
    • Dec 2018
    • 66
    • Hungary
    Hello everyone. I looking for a bios dump for this laptop. Razer Blade RZ09-0083 motherboard number: GA-EVEMLK rev:1.0
    It was another shop and they gave back with an empty bios chip.
  • istvanszasz99
    Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
    by istvanszasz99
    Product Name: Razer Blade 15 (2022)
    Product ID: RZ09-0421
    Motherboard: CH580
    BIOS Versions I work with: 2.02 & 2.06
    Bios File Size: 32,768 KB
    Dear Forum Readers!
    I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
    I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
    The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
    !!! MY RAZER BLADE...
    11-24-2025, 05:52 PM
  • theplop
    Razer blade 2022, 14" PI480 wont boot to OS, freezes
    by theplop
    Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
    I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
    I've run memtest quite a few times, and more often then not...
    03-20-2025, 06:42 PM
  • 0xx
    2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
    by 0xx
    Hi folks,
    My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
    What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
    I assumed that Windows Update was interrupted due to closing...
    09-14-2025, 03:46 PM
  • shellybelly
    Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
    by shellybelly
    Back Story
    I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
    So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
    08-27-2023, 10:40 PM
  • Awdev
    Razer Blade 15 (2019) RZ09-03006E92 need BIOS Image
    by Awdev
    S/N is BY2011A72401766
    Full name: RZ09-03006E92-R3U1 Razer Blade 15” (2019) | RZ09-03006
    MB Model is: DA530-MB
    Dump is below, Laptop can do EC Reset but cannot boot. Suspect its BIOS or EC....
    10-18-2025, 02:13 AM
