Gigabyte GA-EVEMLK RAZOR BLADE RZ09-00830
  • Daudi83
    • Dec 2018
    • 66
    • Hungary
    Hello everyone. I looking for a bios dump for this laptop. Razer Blade RZ09-0083 motherboard number: GA-EVEMLK rev:1.0
    It was another shop and they gave back with an empty bios chip.
  • Heitor - AWS Informática
    Razer Blade 2020 RZ09 03519E11 - BIOS Request
    by Heitor - AWS Informática
    Hi, everyone!
    I've a Razer Blade 2020 on my bench today, all stand-by tensions are OK, but we've no action when I press the power button.
    Here's some informations about the laptop and the original file backup:
    Laptop Model: Razer Blade 2020
    MB Model: ol510mb v1.0
    P/N: RZ09 03519E11
    S/N: 622048M10000619
    Many thank's in advance! And if I broke any rule, sorry, I'm a rookie here, just tell me how can I fix that ...
    Today, 08:05 AM
  • istvanszasz99
    Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
    by istvanszasz99
    Product ID: RZ09-0421
    Motherboard: CH580
    Bios File Size: 32,768 KB
    Dear Forum Readers!
    !!! MY RAZER BLADE...
    11-24-2025, 05:52 PM
  • theplop
    Razer blade 2022, 14" PI480 wont boot to OS, freezes
    by theplop
    Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
    I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
    I've run memtest quite a few times, and more often then not...
    03-20-2025, 06:42 PM
  • 0xx
    2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
    by 0xx
    Hi folks,
    My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
    What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
    I assumed that Windows Update was interrupted due to closing...
    09-14-2025, 03:46 PM
  • shellybelly
    Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
    by shellybelly
    Back Story
    I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
    So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
    08-27-2023, 10:40 PM
