Adp70 la-c832p
  • omar mokhtar
    • Nov 2016
    • 38
    • egypt
    Adp70 la-c832p
    ineed this file
    any one can help
    • 21679
    Re: Adp70 la-c832p
    Originally posted by omar mokhtar
    ineed this file
    any one can help
    It would be helpful if we had a bit more information,such as the laptop model number, serial number or service tag
    • omar mokhtar
      • Nov 2016
      • 38
      • egypt
      Re: Adp70 la-c832p
      this model
      • hardware1
        • Sep 2021
        • 2946
        • N/A
        Re: Adp70 la-c832p
        this model
        You have already wrote the Motherboard number in the title.
        He asked you to write your Device Model Number and Serial Number.
        Also if you have the original Bios upload it here.
        all donations are welcome,
        • binoyroy
          • Sep 2017
          • 51
          • bangladeah
          Re: Adp70 la-c832p
          ineed this file
          any one can help
          Try this...
          • omar mokhtar
            • Nov 2016
            • 38
            • egypt
            Re: Adp70 la-c832p
            not work
            but this one give flash back that it will open
            with out data
            • omar mokhtar
              • Nov 2016
              • 38
              • egypt
              Re: Adp70 la-c832p
              only model i have
              E5470
              • mshone
                Lenovo thinkpad P1 G2 UUID and Serial number/mashine type unknown
                by mshone
                Sorry if topic if misplaced. Have lenovo thinkpad P1 gen2 with Xeon E-2276M CPU and NVIDIA® Quadro® T1000. It is a new board replaced. Old board was P1 G1 model with i7 and it is defective. I ordered a new one with xeon, but is gen 2. Laptop case is suitable for this motherboard, with some little difference (GPU fan and subcard).Ok, ordered and replaced and GPU fan and subcard and now laptop is working fine, but serial number and UUID is unknown. Ok, i readed several topics here and found Thinkpad maintenance disk, but.....which values to type? How to find data base with those values? serial...
                08-29-2025, 06:41 AM
              • Friend33
                Changing BIOS Serial Number After Motherboard Replacement on EliteBook x360 G3
                by Friend33
                I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at...
                06-16-2024, 03:13 PM
              • sikocan
                Lenovo X1 Carbon 9th Gen Black Screen
                by sikocan
                I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                SN: PF3G1REP
                MODEL: 20KW-00J1AU
                PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                06-24-2025, 09:01 PM
              • walad_shaey
                lenovo iq1x0ms serial number
                by walad_shaey
                error massage invalid serial number
                pls add serial number
                model: Lenovo iq1x0ms
                s.n : S4V13095...
                07-27-2025, 09:45 PM
              • AWFRONT
                [Help Please!] Lenovo ThinkBook Plus Gen4 Twist-Help Needed with Restoring Serial Number and Product ID
                by AWFRONT
                I have recently purchased a Lenovo ThinkBook Plus Gen4 Twist with Dual Screen. Here are the links for the product information:
                ThinkBook Plus Gen 4 (13″ Intel) | 13.3″ & 12″ Dual-Screen 2-in-1 Business Laptop | Lenovo UK
                However, somehow the serial number and the product name is no longer showing under the BIOS, Windows 11 or Lenovo Vantage.
                Strangely the laptop's under cover does not show any information about the Make, Model, Type or Serial Number (No sign of tampering but no labels etc...). I am not sure what to do.
                I do not have access to the original box...
                06-21-2025, 11:09 AM
