G531GT bios needed or clean ME
  • pcrepai
    • Jul 2021
    • 46
    • Nederland
    Hello friends.
    I have laptop, turning on and its booting to windows but nothing on screen, after bios reset (cmos battery out), motherboard boots with working screen, but if I put battery back issue come back ( nothing on screen.),
    can someone check my bios ( CLEAN ME), or maybe someone can extract one from ASUS site.
    motherboard G531GT rev. 1.5
    original bios in attachment.
    thanks in advance
  • Lisa Su
    Badcaps
    • Apr 2021
    • 216
    • Taiwan
    Re: Asus G531G bios needed or clean ME
    Try this
    • tccyo22
      • Oct 2019
      • 73
      Give this a try
      • pcrepai
        • Jul 2021
        • 46
        • Nederland
        Lisa Su !!! Works like a charm THANK YOU !!!!
        • belikeimpasta
          • May 2023
          • Malaysia
          Originally posted by tccyo22
          Give this a try
          Hey man, i know this is old post, im facing the same issue, could you do the same with this bios ? i would really appreciate it if you could help
          My mobo version : G531gt REV 1.5
          i included the bios.
          • newdes
            • Aug 2018
            • 34
            • MX
            Hello, could someone help me Clean the ME region from my BIOS? the MB is Asus G531G Rev. 1.4
            GT531GT-AL249T
            SN: K5NRCV00T22119B
            CN: DWT2
            Thank you very much: D
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Read the rules before posting:
              Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
              Become a Badcaps supporter
              Thanks to all supporters.
              • laptopgreen
                • Aug 2017
                • 26
                • VN
                Hello bro, can you Remove pass pls!
                Bios above not detect SSD or can't install VGA. Thanks all!
                Model: G531GD-AL025T
                S/N: K8NRCV053565356
                Board code: G531GT Rev 1.5
                • shiyab
                  • Sep 2023
                  • 1592
                  • india
                  its bios pass unlock
                  • laptopgreen
                    • Aug 2017
                    • 26
                    • VN
                    Thank you very much!
                    Bios ok, i can install VGA. Thanks!
                    • mitchw
                      HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
                      by mitchw
                      Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
                      After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
                      After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
                      I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
                      04-29-2025, 03:45 PM
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
                    • BlueNitesFire
                      I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
                      by BlueNitesFire
                      So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
                      03-08-2025, 03:49 PM
                    • Technodoc
                      ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                      by Technodoc
                      Asus laptop G614JZ-N3012W Rog Strix with i7
                      Mainboard G634J-PMV-VGT
                      6050A3441302-MB-A01
                      2023-02-10
                      Power button works okay....power light goes on
                      Red "bottom" leds go on
                      Charging led works
                      Fans do not spin, capslock key does nothing, screen stays black
                      I would like to program the bios again, to rule out a corrupted bios.
                      However I run into a size error
                      The bios chip is a Winbond 25R256JVEN
                      Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                      02-24-2025, 04:46 AM
                    • techlab
                      HP Elite Dragonfly Bios Crashed - HELP NEEDED
                      by techlab
                      Hi Guys,
                      Looking for some help with an HP Elite Dragonfly.
                      The customer explained it was updating the BIOS, the flashing completed, but afterwards the laptop wouldn’t power back on.
                      • The laptop has no power but does take the correct voltage.
                      • It shows 5 flashes white/amber, which indicates a BIOS issue.
                      • I backed up the original BIOS to extract the feature byte etc.
                      • I then flashed the BIOS with a clean version from HP’s website, but the laptop still gives 5 white/amber flashes.
                      Just wanted to pick your brains on this — has anyone come across this before or...
                      08-29-2025, 05:29 AM
