Surface pro 4 bios repair
  • sarkov
    • Aug 2016
    • 12
    • Spain
    Hello everyone, could you give me a hand? I need to clean the region of this bios that I don't know if it's blocked either, the equipment turns on but shows a yellow band above and it doesn't go there, thanks for the help regards
  • peste
    • Dec 2016
    • 12811
    • ROMANIA
    Re: Surface pro 4 bios repair
    try..
    • Kabylion
      • Oct 2022
      • 10
      • France
      Hello guys I have problem with this bios bin file
      Every time I try to repair me region and touch screen no success ( I can not install firmware for touchscreen and me region on windows or when it boot up)
      Can someone help me it's bin file from surface pro 4 i5 6300u 4gb ram
      And I have a question can I swap this bin file to another surface pro 4 same model
      Thank you for helping me
      • peste
        • Dec 2016
        • 12811
        • ROMANIA
        try post #2..
        • Kabylion
          • Oct 2022
          • 10
          • France
          Originally posted by peste
          try post #2..
          Thank you I will try it
          Is it normal to use other bin file from the same surface model because I have a function one
          If it's possible I will extract bin from it and program it
          • Kabylion
            • Oct 2022
            • 10
            • France
            try post #2..
            It's not working nothing on th display 😔
              • 20914
              try
              • Kabylion
                • Oct 2022
                • 10
                • France
                Originally posted by SMDFlea
                try
                Me région its corrected but touche screen is not working
                Any idea!!
                And thank you for helping me
                • TTR
                  • Apr 2020
                  • 24
                  • Poland
                  Hi
                  I have surface pro 4 with i7-6550u CPU
                  The problem is tablet cannot update ME Region via windows update
                  After the restart i have surface logo and tablet is trying to update ME region but restarts.
                  After looking in the device manager I have an exclamation mark in surface ME and code 10.
                  I dumped the contents of bios via a programmer and tried to clean ME region in FIT but got the following error message.
                  If someone could clean me region for me it would be great.
                  Thank you
                  • ajbernasko
                    • Mar 2022
                    • 229
                    • ghana
                    Hi, i have a surface pro 4 which does not charge over 49%. I used another firmware and now battery has been able to charge past 49%, it is at 76% now as I write for this request. I hope you can help me clean the file. Thank you
                    • durango legrand
                      • May 2020
                      • 15
                      • benin
                      Re: MS Surface no touchscreen after cleaning ME Firmware **FIX**
                      Good morning
                      please i have a surface pro 4 X911788-009 which turns on and restarts right after the surface logo. I would like you to help me fix his bios without losing touch functionality. here is the original bios
                      thanks
                      • wommers
                        • Aug 2022
                        • Ukraine
                        Hi. I have a Surface pro 4 which turns on and restarts after logo. Maybe who a help me fix BIOS without losing touch functionality. Original bios
                        • battleking67
                          • Aug 2020
                          • 5
                          • germany
                          hey i have a surface 4 pro
                          the Bios is corrupted
                          i have flash with one and it worked but without touch
                          i have the backup of original image
                          can someone help me to get working touch
                          or repair my original image ?
                          surface pro 4 1724 128GB 095788554353
                            • 20914
                            Post the laptop serial number - https://www.badcaps.net/forum/showthread.php?t=103570
                            • battleking67
                              • Aug 2020
                              • 5
                              • germany
                              i have edited my post
                              • battleking67
                                • Aug 2020
                                • 5
                                • germany
                                • KABY
                                  • Dec 2022
                                  • 71
                                  • algeria
                                  HELLO I HAVE SURFACE PRO 4 NOT TURNING ON ...CORRUPTED BIOS AFTER UPDATE ...
                                  IM LOOKING FOR SOMEONE TO HELPING ME !
                                  CAN SOMEONE REBUILT THE ORIGINAL BIOS !!
                                  THANKS FORE HELPING ME
                                  SURFACE IS SP4 I5 6300U 8G RAM 256G SERIAL NUMBER IS 056498364953
                                  • vatecnica
                                    • May 2021
                                    • 41
                                    • Argentina
                                    Hello friends in this time i haace an surface 4 pro it wont start, i have all power rails, but when y touch the power button dont do nothing!
                                    it said 1724 256gb 018983661253
                                    hope its the bios the problem!! crossing fingers!
                                    thanks a lot for the help!
                                    • Penetre
                                      Surface Pro 6 Bios (Clean Region ME + OFF motherboard)
                                      by Penetre
                                      Hello everyone, I write in case you can help me with my little Surface. I am a person who wants to try to fix something and usually gets into more trouble.
                                      I have been trying to get the materials for 8 months to be able to desolder and flash the bios. After getting the programmer and the hot air station, I killed the surface.
                                      I have managed to extract the Bios from the chip and modify with HxD the region Me, to leave it clean, using the files of the same version.
                                      I attach the Original files and with R.Me clean, in case someone could check,...
                                      09-12-2022, 02:28 PM
                                    • Citymin
                                      by Citymin
                                      S/N : 5RNK9FFT70...
                                      08-05-2025, 05:12 AM
                                    • Forest79
                                      by Forest79
                                      However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                      07-23-2023, 07:39 AM
                                    • maanee11
                                      Help to get Lenovo BIOS bin file for Thinkpad T560
                                      by maanee11
                                      Hello Everyone,
                                      I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                      https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                      In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                      05-15-2022, 11:59 AM
                                    • Sebastian Codrean
                                      BIOS file for ASUS F542UN laptop
                                      by Sebastian Codrean
                                      Hello to all of you! I need help with a BIOS file.
                                      The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                      So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                      02-20-2025, 10:25 AM
