Surface pro 4 bios repair
  • sarkov
    • Aug 2016
    • 12
    • Spain
    Hello everyone, could you give me a hand? I need to clean the region of this bios that I don't know if it's blocked either, the equipment turns on but shows a yellow band above and it doesn't go there, thanks for the help regards
  • peste
    • Dec 2016
    • 13793
    • ROMANIA
    Re: Surface pro 4 bios repair
    try..
    • Kabylion
      • Oct 2022
      • 10
      • France
      Hello guys I have problem with this bios bin file
      Every time I try to repair me region and touch screen no success ( I can not install firmware for touchscreen and me region on windows or when it boot up)
      Can someone help me it's bin file from surface pro 4 i5 6300u 4gb ram
      And I have a question can I swap this bin file to another surface pro 4 same model
      Thank you for helping me
      • peste
        • Dec 2016
        • 13793
        • ROMANIA
        try post #2..
        • Kabylion
          • Oct 2022
          • 10
          • France
          Originally posted by peste
          try post #2..
          Thank you I will try it
          Is it normal to use other bin file from the same surface model because I have a function one
          If it's possible I will extract bin from it and program it
          • Kabylion
            • Oct 2022
            • 10
            • France
            try post #2..
            It's not working nothing on th display 😔
              • 22156
              try
              • Kabylion
                • Oct 2022
                • 10
                • France
                Originally posted by SMDFlea
                try
                Me région its corrected but touche screen is not working
                Any idea!!
                And thank you for helping me
                • TTR
                  • Apr 2020
                  • 24
                  • Poland
                  Hi
                  I have surface pro 4 with i7-6550u CPU
                  The problem is tablet cannot update ME Region via windows update
                  After the restart i have surface logo and tablet is trying to update ME region but restarts.
                  After looking in the device manager I have an exclamation mark in surface ME and code 10.
                  I dumped the contents of bios via a programmer and tried to clean ME region in FIT but got the following error message.
                  If someone could clean me region for me it would be great.
                  Thank you
                  • ajbernasko
                    • Mar 2022
                    • 229
                    • ghana
                    Hi, i have a surface pro 4 which does not charge over 49%. I used another firmware and now battery has been able to charge past 49%, it is at 76% now as I write for this request. I hope you can help me clean the file. Thank you
                    • durango legrand
                      • May 2020
                      • 15
                      • benin
                      Re: MS Surface no touchscreen after cleaning ME Firmware **FIX**
                      Good morning
                      please i have a surface pro 4 X911788-009 which turns on and restarts right after the surface logo. I would like you to help me fix his bios without losing touch functionality. here is the original bios
                      thanks
                      • wommers
                        • Aug 2022
                        • Ukraine
                        Hi. I have a Surface pro 4 which turns on and restarts after logo. Maybe who a help me fix BIOS without losing touch functionality. Original bios
                        • battleking67
                          • Aug 2020
                          • 5
                          • germany
                          hey i have a surface 4 pro
                          the Bios is corrupted
                          i have flash with one and it worked but without touch
                          i have the backup of original image
                          can someone help me to get working touch
                          or repair my original image ?
                          surface pro 4 1724 128GB 095788554353
                            • 22156
                            Post the laptop serial number - https://www.badcaps.net/forum/showthread.php?t=103570
                            • battleking67
                              • Aug 2020
                              • 5
                              • germany
                              i have edited my post
                              • battleking67
                                • Aug 2020
                                • 5
                                • germany
                                • KABY
                                  • Dec 2022
                                  • 71
                                  • algeria
                                  HELLO I HAVE SURFACE PRO 4 NOT TURNING ON ...CORRUPTED BIOS AFTER UPDATE ...
                                  IM LOOKING FOR SOMEONE TO HELPING ME !
                                  CAN SOMEONE REBUILT THE ORIGINAL BIOS !!
                                  THANKS FORE HELPING ME
                                  SURFACE IS SP4 I5 6300U 8G RAM 256G SERIAL NUMBER IS 056498364953
                                  • vatecnica
                                    • May 2021
                                    • 45
                                    • Argentina
                                    Hello friends in this time i haace an surface 4 pro it wont start, i have all power rails, but when y touch the power button dont do nothing!
                                    it said 1724 256gb 018983661253
                                    hope its the bios the problem!! crossing fingers!
                                    thanks a lot for the help!
                                    • AminoWASD
                                      • Jul 2024
                                      • 4
                                      • Nigeria
                                      try..
                                      What's the password pls
                                      • peste
                                        • Dec 2016
                                        • 13793
                                        • ROMANIA
                                        try...
                                        • Penetre
                                          Surface Pro 6 Bios (Clean Region ME + OFF motherboard)
                                          by Penetre
                                          Hello everyone, I write in case you can help me with my little Surface. I am a person who wants to try to fix something and usually gets into more trouble.
                                          I have been trying to get the materials for 8 months to be able to desolder and flash the bios. After getting the programmer and the hot air station, I killed the surface.
                                          I have managed to extract the Bios from the chip and modify with HxD the region Me, to leave it clean, using the files of the same version.
                                          I attach the Original files and with R.Me clean, in case someone could check,...
                                          09-12-2022, 02:28 PM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • maanee11
                                          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                                          by maanee11
                                          Hello Everyone,
                                          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                                          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                                          In the website, you can only see specs etc.
                                          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                                          11-08-2025, 04:08 AM
                                        • Forest79
                                          by Forest79
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
                                        • maanee11
                                          Help to get Lenovo BIOS bin file for Thinkpad T560
                                          by maanee11
                                          Hello Everyone,
                                          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                          05-15-2022, 11:59 AM
