Acer a514-54 bios needed
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hi, i have one laptop acer aspire A514-54 , laptop turn on but no display.
serial number :NXA2ASM00210203BF53400
snid: 10201534934
part no: NX.A2ASM.002
thanks.
Attached FilesComment
good day ! ..i have acer A514-54-37YX
N20C4
issue : critical battery low even charger is connected
please help meg fix this , i attach the old bios bin file. thank you very much
S/N : NXA27SP00305008A7E3400
SNID: 05003545434
Board ID : FH5AT LA-K091P rev 2.0 2020-09-11Attached FilesComment
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
hello is this right ? thank you
the orig size if 16mb .. i compress it with rarAttached FilesComment
Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
my file is extracted from latest update and put your DMI in it, I think is a harware problem. Take off ssd, wi-fi, battery, change RAM andCMOS battery, see what's happening.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
good day ! ..i have acer A514-54-54u8
N20C4
S/N : NXA68EK0021360EC573400
SNID: 136060334
Board ID : FH5AT LA-K093P rev 1.0 2020-12-30Attached FilesComment
Serial Number : NXA68EK0021360EC573400Attached Files
XM25QH128A@SOIC8 no display.rar
Good day sir i need help Please fix my bios
power but no display
A315-58-397k
S/N: NXADDSP00J2360417A3400
SNID 23601676234
board id LA-K093P
THANK YOUAttached FilesComment
A315-58-397k
SNID 23601676234
board id LA-K093P
THANK YOU
A315-58-397k
SNID 23601676234
board id LA-K093P
THANK YOU
https://www.badcaps.net/forum/troubl...pire-3-a315-58----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Model: ACER Aspire 5 A514-54-50LD
Board: FH5AT LA-K091P Rev 2.0 2020-09-11
SN: NXA2BSP002047106413400
SNID: 04706713734
I am attaching a backup of my current BIOSAttached FilesComment
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
by EbrahimSiamiHello everyone,
I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
**Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
**What I have tried so far:**
1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...-
Channel: BIOS Requests ONLY!
07-02-2025, 02:31 PM -
by NecroFlexI have an Acer Aspire 1 A115-32-C28P laptop that tries to boot for 5s and then shuts off. (Mobo name GH5JJ/GH7JJ LA-K701P Rev C1)
I suspect the BIOS might be the issue, but ACER website doesn't come with a BIN file, only an EXE that doesn't contain the full image. I tried searching for a BIOS bin but no luck.
I have attached both the bios i read from the chip and the latest ACER bios. Thanks for any help in advance!...-
by Wg188I have an Acer veriton Z4660G all in one pc,
Model: Z4660G-I5850H1 (VZ4660G_W)
Need bios dump and schematic would save my life !
to make a long story short I bought this all in one used
with a broken lcd, with the objective of making a custom desktop out of it
,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...-
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
by totofHello
I need the latest bios for Acer Aspire V3-372T-58TH (Intel Core i5-6200U Skylake).
My computer start but screen remains black and boot loop every 10 seconds. All voltage seems good so it may be a corrupted bios (I hope).
Model N15W8
SN NXG7CEF006551013E46600
MIHAWK MB 15208-2 BOARD
448.06J05.0021
MB NBG7C110035510009A6600...-
Today, 12:25 PM -
- Loading...
