[REQUEST] Thinkpad L490 Bios file ?
  • jhay06
    • Jan 2023
    • 12
    • Philippines
    Hi ,
    Last week i bricked my Lenovo Thinkpad L490 , i think NVRAM reset caused it.
    because i'm trying to install hackintosh to that laptop . and as per forum they recommend to reset the nvram ,
    So after i install hackintosh , and reset nvram then restart the device , my Laptop is not booting , but there is a sign of life because , because it has a LED light , Power on light , ESC light is on and Capslock light is on, but the laptop has no activity . it stays on black screen .
    i believed NVRAM reset messed my BIOS rom.
    now , I'm planning to buy CH341A SPI flasher, since this is my first time to do flashing , I have not familiar / zero knowledge using it.
    but per google. I need to have Bios.bin file , but unfortunately i can't find it to lenovo website, there is available bios firmware but it has no .bin file on it. It contains only .FL1 and .FL2 file .
    Is there someone here have the same device as mine ?
    would like to request a copy of your Bios rom so i can bring my laptop to life.
    thank you very much
    • 20977
    Re: [REQUEST] Thinkpad L490 Bios file ?
    Originally posted by jhay06
    Hi ,
    What method did you use to reset NVRAM ,and did that forum recommend to make a bios backup before trying anything
    • jhay06
      • Jan 2023
      • 12
      • Philippines
      I Used the menu from OpenCore there is nvram reset there .
      actually on my DELL laptop, resetting nvram with OpenCore is working without problem . but on this laptop L490 it is very strange though i saw on lenovo forums , resetting nvram assumes to be safe .
      I did not read anything regarding on bios backup .
      and now , I'm looking on how can i bring my laptop to life , i believe this is BIOS problem since i found out that there is other user at lenovo forums experience the same situation right now when they try to reset their nvram.
      I'm planning to buy that CH341A eeprom flasher , or if there is a recommended tools?
      i have no idea on how can i identify the SPI chipset of the laptop since this is my first time.
      And also im looking for a copy of BIOS file for this laptop
      L490 20Q6 ,
      Thank you very much
      • jhay06
        • Jan 2023
        • 12
        • Philippines
        any one ? ,
        also is there a way i can extract the original bios from the bricked laptop ? i saw users from other forums which i am not currently member , i just saw it from google , they extract their original bios rom even it is was bricked then post to that forum and then the thread owner fixed the problematic bios rom then reupload the firmware .
          • 20977
          L490 20Q6 ,
          Thank you very much
          Find your motherboard part number,if its an NM-B931 you can download the schematic and boardview here -> https://www.badcaps.net/forum/showthread.php?t=100946 .Search for the SPI in the schematic to find the bios chip(s) , then find its location on the motherboard using the boardview. Post the part number that is etched on top of the chip and post a picture of it,just to verify if its a WSON8 or SOP8 chip and someone will tell you if its the right chip or not as there will be more than one SPI chip on the board for different purposes.Then,if the chip is 1.8V you will need a 1.8V adapter ,if its 3.3V you don`t.If you havn`t got the tools to desolder the chip then you can try a clip for SOP8,or for WSON8 a pogo pin adapter,or solder wires from the programmers adapter board to the chip legs,solder or surrounding parts connected to the traces.If you cheap out and buy a CH341A it could need modifying to 3.3V from 5V before you use it to make a bios backup - https://www.badcaps.net/forum/showpo...40&postcount=2
          • jhay06
            • Jan 2023
            • 12
            • Philippines
            Thanks for the response
            I saw from the link that TL886II is the recommended spi programmer
            would like to confirm if is this the one that they were talking about (see attached image) ?
            also , i saw ezp2019 on the list of recommended flasher , but i found ezp2023 ? can you take a look if this will work
            https://www.lazada.com.ph/products/o...ist.84&stock=1
            do i need to do modification like what you said on ch341 (3.3v-5v) if i will buy ezp or tl886? thanks
            • jhay06
              • Jan 2023
              • 12
              • Philippines
              i order ezp2019 through online i ordered with 12 expansion board .
              • jhay06
                • Jan 2023
                • 12
                • Philippines
                okay got my ordr ezp2019 will try it now , if somone can help me to revive my laptop
                • jhay06
                  • Jan 2023
                  • 12
                  • Philippines
                  okay , i think this this is the bios chip i guess? would you know? Winbond-25Q256JVEQ
                    • 20977
                    You have found the correct bios chip,but,it is not in the support list https://www.hklrf.com/24download/img/EZP2019-List.txt .You can select a different chip instead, W25Q256 or GD25Q256 and untick the verify setting.The chip type is WSON8 you will not get a clip onto it,it must be desoldered and out into or on an adapter board, or run wires from the adapter board. The EZP programmers are problematic reading and writing anything 8MB or higher, in the manual its recommended to turn the speed down;
                    Quote:
                    Note: Some 8M or more chips are detect ID unstable. recommended to select the chip
                    manually. In addition, if some errors when reading and writing, please to lower the
                    speed.
                    Its essential that you make a good backup, don`t erase the chip or try writing anything to it yet
                    • jhay06
                      • Jan 2023
                      • 12
                      • Philippines
                      do you mean i should buy a replacement chip ?
                      or do you want me to try to flash W25Q256/GD25Q256 file ?
                      I bought ezp2019 with wson8 extension board ? should i need to desoldered it ?
                      Actually im not good in using solder iron , so if i can prevent to use it , i will prevent it
                      btw , if my chip is not supported do you have any bios flasher to recommend that can support my chip ?
                      • jckun
                        • Apr 2023
                        • 3
                        I have the same issue also after using the clear NVRAM.
                        Were you able to find the bin files?
                        • maanee11
                          Help to get Lenovo BIOS bin file for Thinkpad T560
                          by maanee11
                          Hello Everyone,
                          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                          05-15-2022, 11:59 AM
                        • Forest79
                          by Forest79
                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                          07-23-2023, 07:39 AM
                        • iZakre
                          HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                          by iZakre
                          Hello everybody!
                          To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                          The thing is that I had installed TeamViewer and could log into the computer...
                          02-19-2023, 02:27 PM
                        • joshAU
                          BIOS file for N550JK (original dump attached)
                          by joshAU
                          Hi all.
                          I'm looking for a BIOS file for an Asus N550JK.
                          I have a Asus R552J, which I believe is identical to the Asus N550JK.
                          I downloaded the latest BIOS (210) for the R552.
                          It is named N550JKAS.210.
                          The BIOS file is however only 6mb in size.
                          I've read the chip with a CH341A programmer and verified the file.
                          That file is actually 8mb in size.
                          I'm wanting to remove the BIOS password from this unit.
                          It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                          08-09-2022, 08:06 PM
                        • h91
                          Bios file Thinkpad P15s Gen 1
                          by h91
                          Hello
                          Please , I need the bios file (.bin) of a lenovo Thinkpad P15S gen 1.
                          Motherboard number NM-C931 Rev 1.0
                          And where can I find the bios chip on the motherboard ?
                          And thanks ....
                          01-30-2023, 04:42 PM
