Thinkpad L480 Bios repair
  • makisdal
    • Jul 2015
    • 20
    • GREECE
    #81
    After i patched the bios and did the steps according to the guide,
    I reflashed the original bios and laptop stucks in : Entering bios.....
    Could someone help me?
    Type 20LT-S7DY00 S/N:PF-1GHWNB
    • artvandelay2
      • Jun 2025
      • Sweden
      #82
      Originally posted by bannanaman
      Thank you! This helped me too although I have the ThinkPad L480 Type 20LS not 20LT. I had the same errow showing "(A7) Me Downgrade - Request MeSpiLock Failed" and always shutting down after ~40 seconds or less indepentendly if I was in BIOS or OS. The BIOS-Chip is a MX25L12873F.. near the Intel WiFi-Module and above the second RAM-Slot.
      Now it runs fine without any error message. The only question I have here is if it is expected to run fine like in the sense if the BIOS is somehow less important atleast if it is in the same category as in product line, model no. etc.
      The problem accured after an installation of Kubuntu, as far as I understand the BIOS may got bricked with an update via Kubuntu or maybe it has somethin to do with SecureBoot or TPM, I really don't know but maybe someone can explain what it could really have been. Atleast I therefore deactivate now within the BIOS any update-mechanism for the BIOS, especially before installing a new OS etc. (BIOS -> Security -> UEFI BIOS Update Option -> Windows UEFI Firmware Update: Disabled; I don't know if I should also disable "Flash BIOS Updating by End-Users".
      Something I don't understand is why Lenovo doesn't have also the BIOS-File solely on their pc-support help for specifically this and also other laptops.
      For now I don't need any assistance or else but I leave this post for documentation purposes so other Users, not having the 20LT-version but the 20LS, can hope that this BIOS also works.
      Thanks again everyone for the work and help, have a nice day!
      I have this exact issue with my L480, and it emerged after i installed Debain 12 instead of the previous windows 10 os. I have tried to flash the bin file extracted from the rar file but couldn't get the broken laptop to read from the USB, i have tried several different key combinations when booting but still it just shuts down after about 30 seconds with the (A7) Me FW Downgrade - Request MeSpiLock Failed error. How did you manage to flash the bios?
      Specs:
      Machine type model: 20LTS4NY00
      SN: PF1HKU2G
      System board serial number: L1HF8BP05Y8
      corrupted bios: R0QET67W
      Should also mention that the ME firmware version filed is blank.
      I will much appreciate any help on this issue
        • 22424
        Specs:
        SN: PF1HKU2G
        post your bios backup
        • NighterBG
          • Nov 2025
          • Bulgaria
          #84
          My problem is as follows. Lenovo L480 20LTS4WC00 /N: PF14L40V no picture and esc and capslock are lit. I would like help with this. I am sending the wrong file.
          Thanks!
          • niggi
            • May 2016
            • 219
            • UAE
            #85
            Originally posted by hoaca388
            Re: Thinkpad L480 Bios repair
            L480 Laptops (ThinkPad) - Type 20LT
            thanks working file
            • mepttbblk
              • Jan 2022
              • 39
              • Ukraine
              #86
              Hi. I have l480 Lenovo with no image on screen, beeping melody trying turning on and stuck.
              NM-b461
              sn pf-1eh677
              type 20ls-001age
              • danito
                • Jun 2016
                • 1303
                • Romania
                #87
                NM-b461
                sn pf-1eh677
                type 20ls-001age
                try
                • mepttbblk
                  • Jan 2022
                  • 39
                  • Ukraine
                  #88
                  Originally posted by danito
                  try
                  Thank you, but there is no changes, still melody and black screen, Lenovo Pc diagnostics giving me a 010028 code, can't fing any info about it
                  • to5it0
                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                    by to5it0
                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                    I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                    This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                    I have opened the laptop and identified the main BIOS chip...
                    10-24-2025, 01:35 AM
                  • lucaszmn
                    by lucaszmn
                    Problem:
                    Initial Findings:
                    • I concluded that the
                    08-12-2025, 03:01 PM
                  • MaxonDomkrat
                    Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                    by MaxonDomkrat
                    Hi everyone.
                    I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                    07-30-2025, 01:27 PM
                    Lenovo ThinkPad L480 Notebook L Specification for Upgrade or Repair
                    This specification for the Lenovo ThinkPad L480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L480 boardview and L480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                    09-06-2024, 03:30 PM
                    09-06-2024, 03:21 PM
