Apple 16" macbook pro 820-01700 stuck at 5v
  • razer94
    • Nov 2022
    • 8
    • canada
    Hi I have a 820-01700 board that will not boot. Can yall guide me on trouble shooting. It has had previous water damage but was cleaned and working until recently
    It is taking 5v through usb-c and taking 0.05a
    PPBUS_G3H - .297v
    F7000 resistance to ground is 33ohm
    PPDCIN_G3_CHGR - is 5.07V
    I'm not sure how to proceed at this point any help would be appreciated
  • mon2
    • Dec 2019
    • 14239
    Re: Apple 16" macbook pro 820-01700 stuck at 5v
    See attached.
    Remove the 2 fuses @ F7000, F7001.
    Then power up again and measure the voltage to ground of PPBUS_G3H @ pin # 1 of F7000 or F7001.
    Post your measurement.
    Check again after the above fuses are removed.
    • reformatt
      • Feb 2020
      • 1413
      If you are lucky, most common issue is a shorted cap on PP2V5_NAND_SSD1 (C9091, C9092 etc) or worst case, U9080 has decided to short out. The low impedance on PPBUS_G3H isn't a great sign though. Check around the NAND's and U9080 for a short.
      • razer94
        • Nov 2022
        • 8
        • canada
        Originally posted by mon2
        See attached.
        So with both fuses removed voltage at pin #1 is 12.31v. So I am assuming that that side is okay?
        • mon2
          • Dec 2019
          • 14239
          PPBUS_G3H is better but still not the correct voltage.
          See here:
          https://boards.rossmanngroup.com/thr...s-12-3v.62475/
          1) What is the rating of the power adapter being used? It should be 96W or higher.
          2) Is the adapter @ 20V now or still @ 5v for the input voltage ?
          • razer94
            • Nov 2022
            • 8
            • canada
            I'm using a bench power supply with by-3200 power cable.
            Input voltage is still 5v
            • mon2
              • Dec 2019
              • 14239
              If I understand the BY-3200 power cable correctly, your bench power supply is dialed up to 20 volts ? That is, if the logic board is truly requesting 20V, this BY-3200 will supply it?
              The logic board should be @ 20V but only if the ACE controllers are working properly.
              Check the voltage to ground of each of the LDO rails on each ACE controller.
              • razer94
                • Nov 2022
                • 8
                • canada
                Should i still check this with the fuses still removed.
                And yes the power supply is 20v and if it need 20v it will supply
                • mon2
                  • Dec 2019
                  • 14239
                  Yes, fuses off since the consumer side of ppbus_g3h has a short.
                  The adapter voltage should be 20v if the ace (cd3217) controllers are working. Check the LDO rails of each cd3217 ace controller.
                  • piernov
                    • Jan 2016
                    • 4435
                    • France
                    PPBUS_G3H must come first to feed power to T2 for USB-PD negotiation.
                    • razer94
                      • Nov 2022
                      • 8
                      • canada
                      so with fuses removed is there no point to measure the LDO at the ACE controllers?
                      Low impedence in the G3H line is still another problem too
                      • razer94
                        • Nov 2022
                        • 8
                        • canada
                        So i measured the resistance from c9091 pin 1 and c9081 pin 1 and there is 6ohms.i I also see 27ohm from c9091 to ground. Does this mean the NAND is gone?
                        • reformatt
                          • Feb 2020
                          • 1413
                          Usually yes. Very common issue unfortunately. The buck converter shorts PPBUS directly to the NAND's. Game over and you have to replace all 4 from another board. Really bad bad design.
                          Remove U9080 and see if your partial short on PPBUS is gone. If it were just one of the 2.5V caps shorted, then you wouldn't have the short on PPBUS_G3H. This points to failure of U9080 and destruction of the NAND's in turn.
                          • platinumsteel
                            Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
                            by platinumsteel
                            Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
                            03-18-2024, 05:16 PM
                          • martyjelen
                            Apple MacBook Pro 16-Inch 2019 - A2141 - stuck at 5V
                            by martyjelen
                            Hello, I have this Macbook A2141. It stuck at 5V / 0,075A. I measured all 4 ports, all the same. PPBUS_G3H is present but only 12,3V. Should be 12,6V ? according to this article : https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
                            PP3v3_G3H_RTC_X is present - 3,3V
                            PP3v3_G3H_SOCPMU is present - 3,3V
                            ​What else should I check?
                            Thank you for your help.
                            05-05-2025, 01:34 AM
                          • mferna14
                            MacBook Air A2179 stuck on Apple Logo
                            by mferna14
                            Hi all, working on a MacBook Air A2179 EMC 3302 stuck on Apple Logo. Came in dead. There was spillage on both of the USB-C Charge port connector. I replaced the cap 4.7UF 25V near the speaker connector as it was corroded. Replaced USB-C connector with a new one & now I get display. The problem is that gets stuck on the Apple logo & sometimes it even boots up into OS after a very long time & the CPU fan spins fast. Kindly any repair tips will be appreciated. Do these logic board have BIOS, so that I could do a clean up or load a new dump. Thanks in advance.
                            04-06-2023, 03:45 PM
                          • dellxps15
                            macbook pro 13 2016-2017 820-00840 stuck on apple logo
                            by dellxps15
                            hi i got this macbook that was stuck on apple logo. tried ssd on another board and it work perfectly.
                            tried also pram nvram reset, smc reset, safe mode, verbose etc etc but always same thing: laptop power on with chime... stay on apple logo for like 60 seconds and then reboot.
                            today im getting t3 screw and take board apart, but it seems to have no liquid spill or similar. top of the board is perfect and like new....
                            anyone got that similar problem? bios or what ?
                            07-07-2022, 06:50 AM
                          • envym
                            MacBook Pro 2018 with Activation Lock
                            by envym
                            Hi everyone!
                            I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                            I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                            06-27-2025, 08:54 AM
