A1707 Macbook fan at full speed
  • Roll
    • Mar 2022
    • 36
    • Czech Republic
    Hello guys, I have this Macbook Pro with touchbar and it's acting up.
    First it came as completely dead - I found out it was one of thunderbolt controlers. I removed it, laptop came back to life, but one fan was loud. I didn't have replacement IC, so I thought it was in panic mode or something.
    Then new IC arrived - I replaced it, but it still is in full blast mode.
    It gets to full speed right after pressing the power button.
    I tried reseting the SMC and PRAM - no change.
    I installed Fan control app - all temperatures are OK, right side fan works fine, but left one is stuck at highest RPMs. When I try to set it any lower, it does not react at all.
    Is there anything I can do about this? Thanks
  • mon2
    • 13871
    Re: A1707 Macbook fan at full speed
    Swap the fans to see if the good right fan runs in hyper speed on the other side (left).
    Check the pinout of the fan cable in the schematic before proceeding.
    Also see here
    https://youtu.be/MgPighrnTA0
    -- another link on ifixit blamed the fan itself
    • leonemax81
      Macbook a1707 820-00281 Battery no Power
      by leonemax81
      Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
      08-23-2024, 09:24 AM
    • sofles
      Macbook a1707 2017 model 820-00928 GPU issue
      by sofles
      Hello there
      I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
      I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
      11-21-2024, 05:25 AM
    • tommy97
      Apple MacBook A1707 No Audio/Sound
      by tommy97
      I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
      I've also replaced U6300, but the problem persists.
      Here are the current voltage readings:
      • PPV18_S0: 1.8V
      • R6402: 1V
      • R6405: 1V
      • R6403: 1V
      • AUD_SPKRAMP_RESET_L: 1.3V
      • PPBUS: 12.6V
      03-10-2025, 11:22 AM
    • Cemal Odabasioglu
      MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
      by Cemal Odabasioglu
      I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
      Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
      Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
      Observations...
      01-14-2025, 03:54 PM
    • Instafixx
      Macbook A1707 820-00928 Panic Log
      by Instafixx
      Namaste!
      We have a Macbook A1707 which came in for repair. Someone had already tried to work on it and there were traces oh heat and burns on the board.
      The charger was Stuck at 5v and the there was some caps shorted around U3100.
      Turns out there was corrosion under U3100. Same was Reflowed and the Macbook turned on. Works fine but having 1 issue whenever the Macbook is idle and goes into sleep mode. It will WAKE for 1 Second and then do a restart.
      It will Display a Black Screen with error message saying Macbook Restarted because of a problem....
      01-19-2023, 04:15 AM
