820-02100/02098 LCD Backlight Controller IC UP800..
  • PickledOnion
    • Feb 2016
    • 7
    Re: 820-02100/02098 LCD Backlight Controller IC UP800..
    Originally posted by mon2
    Can you share the exact netname used in the schematic? Unable to locate 3.3v_aon. Did you mean PPVIN_P3V8AON ?
    If the power rails for the CD3218 ACE controllers have been met, the ACE controllers will function. They are stand alone devices with embedded microcontrollers. Review each of the power pins on these power delivery controllers.
    So it appears that pp3v3_s2 is low on the input of the cd3218s. I have checked everywhere on this line for shorts there is none.
    pp3v3_s2 is cycling from 0.5v to 1.9v.
    pp3v3_s2 comes from u8100 pmic. I have also checked all the ldos on u8100 there are no shorts or burnt coils. Not sure where to go from here. Was going to try dfu but seems pointless if pp1v8_s2 and awake is also doing same thing(pulsing low)
    I basicly need some good known diode readings from same board hence suggested sharing with the OP.
    • mon2
      • 16121
      For which component do you require the DIODE mode readings ?
      PMIC ?
      • PickledOnion
        • Feb 2016
        • 7
        PMIC ?
        Yes u8100 would probably be a good start.
        • PickledOnion
          • Feb 2016
          • 7
          Here is some readings from my non working board.
          L8280 pp1v2_s2 0.2130 cycling 0 - 0.5v
          l8230 pp1v8_s2sw 0.2860 cycling 0 - 0.7v
          l8220 ppvdd_ecpu_sram_awake 0.3666
          l8290 pvdd_fixed_s1 0.1698 0v no short
          l8200 pvdd_ecpu_awake 0.0795 or 217 ohms tg
          l8272 pp0v81_s1_sram 0.1745
          l8210 ppvdd_gpu_bmpr_s1 0.2443
          l8243 ppvdd2h1_s2sw 0.0489 or 132 ohms tg
          l82AO pp0v575_s1_vddq1 0.1120
          l8260 ppvdd_amph1_s2sw 0.3944
          l8250 ppvdd_avemsr_awakesw 0.1139
          c8162 pp3v3_s2 0.3692 cycling 0 - 1.5v
          ct150 ppv3v3_aon 0.3604 3.3v stable
          c8162 PP1V8_S2SW_CLVR_VDDC1_LDO 0.4759
          c8165 PP0V8_S2_CLVR_VDDDIG 0.2241
          c8180 pp1v5_aon_vcore_mpmu 0.3540 1.5v stable
          r8317 pp1v8_aon 0.4122 1.8v stable
          c8168 pp1v2_aon 0.5864 1.2v stable
          c8152 pp4v9_vpump_mpmu 0.5671
          rd650(pin 2) pp3v8_aon_mpmu 0.3125 slowly cycling 3.79v to 3.81v
          l7860 pp0v855_s2sw_vddcio 0.1655
          l7850 pvdd_soc_s1 0.0221 or 59 ohms
          l7890 ppvdd_amph0_s2sw 0.3878
          l7880 pp1v2_awake 0.2012
          l7830 pp1v8_s2 0.2228 0.7v cycling
          l7820 pp0v95_s2sw_vddcio 0.2942
          l7800 pvdd_dcs_s1 0.1026 or 283.5 ohms
          l7810 pp0v575_s1_vddq0 0.1098
          l7843 ppvdd2h0_s2sw 0.0498 or 135 ohms
          l78A0 ppvdd_disp_awakesw 0.0333 or 89.96 ohms
          c7712 pp3v8_aon_spmu 0.3125
          c7760 PP0V72_S2_VDDLOW 0.2255
          c7763 PP1V2_AWAKESW_BLC 0.6493
          c7768 PP1V2_AON_SPMU 0.6244
          c7767 PP1V8_AON_SPMU 0.3536
          c7780 PP1V5_AON_VCORE_SPMU 0.3525
          c7752 PP4V9_VPUMP_SPMU 0.5662
          • NAZAREPAIR
            • Apr 2023
            • Portugal
            Hello people. I have a question maybe some of you knows the answer, i have this macbook on my hands this time without backlight, i took a lot of messurments around the screen conector and backlight ic, and it looks to me that this is a ic problem. My question is i saw some guy talking that this chip is married to the cpu or something like that, and that can not be replaced. Is this true? I was thinking about order one of this (RENESAS 209100B1), but now i am worried that it wont work, does anybody here can confirm this? Or anybody here replace already this ic succesfully? Thank you so much!
            • Timp74
              • Apr 2018
              • 52
              • Spain
              #26
              To answer my own questions... I finally had the time to look at this machine again now that the boardview is availble. Turns out the machine wasn't powering on because there was crap under the slave PMIC. Took me a while to work out. I noticed that the 1v8_s2 rail was beening pulled up to 2.1v by 3v8_aon, there was 300 ohms between the rails, it should be Kohms. I guess other rails were off too. Anyway I soaked the board in isoproponol for a few hours and ran a flux cleaner under the slave PMIC. The machine now boots and works fine. I don't see any reason the a missing backlight bucks/boost controller IC should stop the boot process. There doesn't seem to much activity on it's I2C bus before AWAKE. The leason learnt is that this macbook won't assert the AWAKE signals unless all the preceding rails are at the correct voltages and drawing the expected current. It seems quite a common place for liquid damaged macbooks to get stuck at once all the obvious things have been fixed.
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • arkkkk
                Baykunl DRO Digital Readout D80M-3V - TFT LCD no image, backlight works
                by arkkkk
                Hello everyone
                A friend gave me this Baykunl D80 DRO (Digital Readout) he uses for a lathe/milling machine. The LCD stopped working, shows no image or color whatsoever, but the backlight works.
                When you power up, sometimes you can see a brief image but for like 1ms then it goes black. That kinda tells me the LCD is actually good and the issue lies elsewhere.
                The board has:
                • 1x ST STM32F103VET6 Micro-controller
                • 1x RAIO RA8876LN4 LCD controller
                • 1x Winbond W9864G6KH-6 SDRAM
                • 1x Winbond W25Q128JV Serial Flash Memory
                • 1x ATMEL ATMLH834 EEPROM
                • 3x Texas
                01-08-2026, 09:43 AM
              • DanPoka
                by DanPoka
                02-15-2025, 05:05 AM
              • omicronns
                Macbook M1 pro 820-02098 no backlight after UP800 (RAA209100B1) replacement
                by omicronns
                I liquid damaged a Macbook, disassembled it and spotted short near UP800. After desoldering it short was gone so I ordered the chip from https://aliexpress.com/item/1005005500396324.html.
                Laptop is turning on, I can see something on the display if I flash strong light at it.
                After replacing the chip, there is still no backlight. I measured components near the chip on both sides of the board again but everything seems fine.
                Next I measured voltages near the chip, there is 5V, 1.2V, also 2.5V on LUXE_C_VDD (seems like it's internally generated by the chip, since...
                02-03-2024, 05:11 PM
              • Comp_Pro
                No Backlight Macbook A1990 820-01041
                by Comp_Pro
                Hello all,
                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                Tests performed:
                There is no backlight even with a good screen.
                Backlight IC is receiving the correct support voltages.
                Fuse F8400 ok
                Current sense resistor R8400 ok
                Backlight IC is receiving 3.3V on enable pin.
                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                Backlight IC receiving 5V from PP5V_G3S
                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                05-06-2024, 10:23 PM
