Macbook M1 pro 820-02098 no backlight after UP800 (RAA209100B1) replacement
  • omicronns
    • May 2023
    • Poland
    I liquid damaged a Macbook, disassembled it and spotted short near UP800. After desoldering it short was gone so I ordered the chip from https://aliexpress.com/item/1005005500396324.html.
    Laptop is turning on, I can see something on the display if I flash strong light at it.
    After replacing the chip, there is still no backlight. I measured components near the chip on both sides of the board again but everything seems fine.
    Next I measured voltages near the chip, there is 5V, 1.2V, also 2.5V on LUXE_C_VDD (seems like it's internally generated by the chip, since only two components connected to that line are the chip and capacitor).
    LUXE_FAULT line has 1.1V not sure if that means that fault was detected or not.
    No voltage is being generated on LP800.
    I noticed that the chip has debug I2C interface. Can something be learned if I would sniff this traffic?
    Any Ideas what could I check next?
    Thanks!
  • Berun
    HP EliteDesk 800 G6 mini - BIOS Chip (GD25B127DSIG) replacement after epic fail :D
    by Berun
    Hello All,
    I tried to read the the BIOs chip(GD25B127DSIG) on the mainbord of an HP EliteDesk 800 G6 mini, because the BIOs had an Admin Lock and I got the "HP Endpoint Security Problem" Screen at every startup which is not very useful when I want to use the PC as a Compute Unit for my home media system somewhere in the cellar, so it should perform a restart without any interactions.
    I only have the CH341APro Programmer available and did the 3V hardware Mod on it before I tried to read the BIOS chip.
    I read the Chip on board 8 times (with power...
    04-09-2026, 06:24 AM
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
  • Loki_Fido
    Requesting help identifying chip in Macbook Pro A2485
    by Loki_Fido
    Hi ya folks,
    I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
    It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
    I replaced it and the SSD are fine. No more shorts.
    But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
    But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
    Chip marking...
    08-07-2025, 10:17 PM
  • ebugs
    Asus laptop EC/SIO chip replacement
    by ebugs
    Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
    I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
    I found the EC chip...
    09-14-2024, 02:09 AM
  • SSBDADC234
    MacBook Pro 14". The screen DP chip failed.
    by SSBDADC234
    When replacing the screen of this MacBook model, the DP855A chip must be moved from the existing screen for the screen to operate properly.
    However, when I removed the DP855A chip from the existing screen, I must have done something wrong and the chip broke.
    Testing the chip pins with a multimeter revealed a short circuit inside the chip.
    Is it impossible to repair this? I couldn't find a programmer for this chip, nor any eeprom programmer software.​...
    04-19-2024, 08:51 PM
