Macbook A1502 not powering on
  • Roll
    • Mar 2022
    • 36
    • Czech Republic
    Hello guys, i have a Macbook Pro A1502 820-3476-A that has no orange light and does not power on.
    I tried replacing the charging port - no difference.
    Board looks very clean, no signs of corrosion.
    It takes 0,01 A from power supply.
    DCIN = 16,5 V
    PP3V42_G3H = 3,4 V
    PPBUS_G3H = 12,3 V
    Adapter sense = 3,4V
    SYS_ONEWIRE is 2,9 V. Is that correct value?
    Any ideas where to look?
  • mon2
    • 14370
    Re: Macbook A1502 not powering on
    PPBUS_G3H = 12,3 V
    SMC is not working. If working, this should be 12,56
    reference reading:
    https://repair.wiki/w/A1502_2013-201...ook_Pro_Retina
    1) Check the voltage to ground on the SMBUS lines (SDA & SCL) of:
    SMBUS_SMC_5_G3_SCL
    SMBUS_SMC_5_G3_SDA
    2) Check the voltage to ground of SMC_RESET_L
    Post your measurements.
    • dellxps15
      • Feb 2014
      • 1591
      • italy
      DCIN = 16,5 V
      PP3V42_G3H = 3,4 V
      PPBUS_G3H = 12,3 V
      try another dcin board (if no green orange light on charger).
      fixed one today. it was dc-in board not working properly. after green light smc will bost ppbus.
