MacbookPro 14 820-02098 liquid damage internal LCD not working
  • xdever
    • Oct 2019
    • Svájc
    I have an A2442 MacBook with 820-02098 board. It had water damage, and some service already worked on the board and removed the HDMI connector.
    When I got it, the machine worked fine, except for half of the keyboard, which needed to be replaced because it got liquid. The back side of the fans had some sticky liquid, so I guess the board had to have some at some point in the past as well, but it seems to be cleaned by the service who tried to repair it. There is no sign of any oxidation or trace of liquid on the board or the connectors. Everything is as clean as it can be. However, after a day of usage, the LCD just turned off. After closing and opening the lid, it was up and running happily again. And then, after about the 10th of such episode, it did not come back anymore. The time when it went off was not related to any movement, and it went away even when I was using it with an external keyboard and screen without moving the machine, and it did not turn off no matter how I moved the LCD. So I doubt that it is related to the flex cable.
    The miniled backlight is working just fine. A dim, blurry picture can be seen through the dark LCD (video here: https://photos.app.goo.gl/ffV9X2uNAmz4DrNN9). Interestingly, immediately after opening the lid, if it has been off for long enough, a trace of a sharp picture appears: the menu bar is clearly recognizable. Then it immediately fades away. It takes time for this to happen again (~a hour). Otherwise, it is just dark. This fade-away effect indicated some kind of power supply failure, but the 3.3V is present (measured in the circuit with a wire soldered on pin 1 of RP700). With the LCD disconnected, I also measured that EDP_PANEL_1V8_EN is present. PP1V8_S2 is present, as the rest of the laptop works perfectly. I measured all the RC filters on the LPDP_INT_DATA* lines, they all seem to be good, no short to each other nor to the ground. I also applied lots of flux and resoldered these filters, even though no trace of oxidation was visible.
    Does any of you have any idea what can cause such behavior and where to look next?
    Thank you
  • Sephir0th
    • Oct 2020
    • 1262
    Re: MacbookPro 14 820-02098 liquid damage internal LCD not working
    And not even one picture shared of the area in question...
    However and honestly: I'm not into Apple devices but if the design here is similar or even the same like at all the other laptops then you're probably looking into the wrong direction. The LCD enable should be present since you can notice the picture. But the really important things to check is whether the main power rail (PPBUS_G3H or however it is called here) is present at the connector (also check diodes/fuses in this area) and whether the backlight enable also has voltages like expected.
    FairRepair on YouTube
    • xdever
      • Oct 2019
      • Svájc
      Since the service cleaned up the board, I don't know which picture to share. It looks like it comes straight out of the factory.
      I checked the main 3V rail: with the LCD disconnected, it is present on the connector, and with the LCD connected, it is present on RP700, as I wrote. I don't see any way to measure this on the connector when the LCD is connected, as there is no way to access any of its pins.
      As I said and the video shows, the backlight is present. Also, shining a strong light on the LCD doesn't show any picture, so I highly doubt that this has anything to do with the backlight.
      • Sephir0th
        • Oct 2020
        • 1262
        Sorry, then it was a misunderstood since for me it looks like you have picture but without backlight.
        Visual inspection with microscope, checking for good values and resoldering of each component between the M1 CPU and the display connector advised. A summary of all voltages present at the connector would be nice if possible. Also a picture of how it looks like around the connector would be good before. In addition I'm interested in how it looks like at the direction of the removed HDMI board. I don't want to be the pessimist guy here but it can be you're dealing with a irreparable M1 damage here.
        Ah and before I do forget: How is it with external display?
        • mon2
          A1466 Macbook Air (Liquid damage repair)
          by mon2
          Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
          Macbook AIR Model A1466 Diagnostic 09-01-2021
          Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
          Problems & Resolutions
          1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
          09-01-2021, 09:31 AM
        • rilley
          MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
          by rilley
          I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
          I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
          My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
          And the resistor L4004 is literally burned.
          From what I see from the schematics, it does not affect any other rails, only the connection to the display...
          07-10-2024, 01:57 AM
        • Jenzo
          MacBook A1989 overheating after liquid damage
          by Jenzo
          Hey everyone,
          Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
          I can't figure out how...
          05-13-2023, 07:58 AM
        • mitchw
          MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
          by mitchw
          Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
          It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
          I quickly took it apart and washed the liquid residue off the mainboard.
          The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
          The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
          Now the laptop...
          07-16-2025, 07:55 AM
        • larrysito111
          dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
          by larrysito111
          got here a liquid damaged alienware
          the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
          so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
          so with the usb-c external monitor is getting to bios and OS
          otherwise not
          so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
          but still not the internal monitor
          (tested 3V and 5V going to the...
          06-12-2025, 04:16 PM
