v1528 in 8067H
  • badal5130
    • Aug 2018
    • 56
    • nepal
    v1528 in 8067H
    hello expert can we used v1528 Mosfet in place of 8067H ??? if not what are the compatible list and how to know if it fits or not...???
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: v1528 in 8067H
    Both are N channel .V1528 is rather bit better then 8067H. However, the package is different. So if you can manage the packaging difference, go ahead with the replacement.
    • badal5130
      • Aug 2018
      • 56
      • nepal
      Re: v1528 in 8067H
      i don't have much knowledge about compatible mosfet and packaging i replaced it with 1528 but no luck.i have a customer laptop found 8067H short.
      • piernov
        • Jan 2016
        • 4437
        • France
        Re: v1528 in 8067H
        https://logi.wiki/index.php/User:Pie...iginal_part.3F
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • Nooy
          VGA MOSfet permanently shorted and loss of MOSfet pad
          by Nooy
          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
          02-14-2024, 02:26 AM
        • AppleLover123
          Asus X712EA 3 volts after the first mosfet
          by AppleLover123
          Hey guys,
          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
          Now i thought something...
          12-15-2024, 07:49 AM
        • MicroSMD Lab
          by MicroSMD Lab
          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
          01-10-2024, 06:36 AM
        • Scotchmist
          Asus GA502D keeps blowing mosfet
          by Scotchmist
          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
          I have removed the mosfet and can run the laptop no problem
          The MOSFET is FDPC5018SG
          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
          08-24-2024, 02:23 PM
