iPhone 5 bootlooping
  • Jenzo
    • Jul 2019
    • 135
    • Belgium
    Hey everyone,
    Working on an iPhone 5, came in for data recovery.
    Phone booted straight into recovery mode, connected it to 3uTools, used "exit recovery mode", and since then it just bootloops. I get the Apple logo, after a good 5 to 10 seconds, then power gets cut and the logo fades.
    Took it out of the housing, only battery, chargeport and screen connected, same issue. took off the heatshield to measure a bit, but I'm not experienced with iPhone 5 so no clue what to check first.
    With a thermal cam I could see L2 heats up to about 45c, and sometimes the U7 chip next to get get a little heatspot close to it. Connected to a power supply it never draws more then 0.29a.
    Where do I go from here? What should I measure? Thanx in advance!
  • Jenzo
    • Jul 2019
    • 135
    • Belgium
    Re: iPhone 5 bootlooping
    Could someone tell me what the regular resistance to ground on PP_VCC_MAIN should be by any chance?
    • mon2
      • 14368
      Review the first post here:
      https://www.ifixit.com/Answers/View/...+then+restarts
      • Jenzo
        • Jul 2019
        • 135
        • Belgium
        Hey! Thanx for the reply, I've checked the area and everything is present. The board is pretty much in mint condition, except for me removing the heatshield.
        • tiny13
          • Jul 2022
          • 17
          • russia
          Hi. you need to check tristar (u2) thermal camera.
          • Jenzo
            • Jul 2019
            • 135
            • Belgium
            Under the thermal cam only the L2 is getting hot, and the U7 a little bit. The tristar doesn't seem to heat up. Also the tristar tester gave no issue.
            • mon2
              • 14368
              https://forum.gsmhosting.com/vbb/f63...ts-up-1872638/
              Do you have schematics for this phone you can post here?
              Remove all power and battery.
              Meter in resistance mode.
              What is the resistance to ground of this L2 inductor?
              • Jenzo
                • Jul 2019
                • 135
                • Belgium
                I came across that forum post, there they measure a short, as far as I can tell I don't have a short.
                I'm working in ZXW so I don't think I can share The boardnumber of the schematic I'm working of is 820-3141-B.
                Resistance is 0.168 to ground.
                • reessi
                  Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                  by reessi
                  With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                  No corrosion any where!
                  Tried a replacement power button off ebay and the same.
                  Very occasionally it will work with the power button connected!
                  Same results with or without the battery.
                  Can it be a fault with the Audio board or the mainboard?
                  The touch Id assembly connects through the Audio board first then to the Mainboard.
                  Flex...
                  06-26-2024, 03:31 PM
                • volinakis
                  Chromebook recovery failed - how to fix it
                  by volinakis
                  So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
                  Finally I found a site where they suggested to try with an older image and ... it worked!
                  What I did:
                  - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
                  09-18-2023, 03:26 PM
                • Spider1211
                  iPhone XS Data recovery from NAND flash
                  by Spider1211
                  Hey guys, I have an iPhone XS which came in as dead. The phone was not worked on before (I was the first to open it). After diagnosis (Splitting board, etc) it's confirmed to have a shorted PP2v63_NAND line.
                  Removed the NAND flash and short is gone on the board. Measuring directly on the NAND, there is about 2 to 15ohm to ground.
                  Is there anyway of backing up data externally in such cases (Client has some very important files and no back ups)?
                  08-22-2022, 09:22 AM
                • ugamazing
                  820-00850 & 820-01949, No WiFi *In Recovery*
                  by ugamazing
                  I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
                  1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
                  2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
                  01-25-2023, 05:39 PM
                • alfredposadas09
                  cant enter recovery mode lenovo c13 yoga chromebook
                  by alfredposadas09
                  cant enter recovery mode lenovo c13 yoga chromebook try esc+refresh+power at first scenario i was able to enter recovery mode but it was failing to reinstall os .. i try to change ssd and when i try this i cant enter recovery mode now...
                  11-09-2024, 10:09 AM
