acer LA-B991p ,It turns off after 4 seconds
  • kokono
    • Jun 2018
    • 203
    Here I want to explain to you about a problem of Acer Model LA-B991P motherboard.
    All voltage rails have been checked. All are there. But the motherboard turns off after three or four seconds.
    I measured these signals:
    EC_RST > 3.3
    PLT_RST > 0
    SYSON >3.3
    PCH_PWROK > 3.3
    SUSP# >3.3
    PCH_RSMRST# > 3.3
    PM_SLP_S4 > 3.3
    PM_SLP_S3 > it comes and goes quickly
    PM_SLP_S5 > it comes and goes quickly
    Please guide me to check more signals.
  • kokono
    • Jun 2018
    • 203
    Re: acer LA-B991p ,It turns off after 4 seconds
    Update :
    SYS_PWROK > 3.3
    H_CPUPWRGD > 0
    EC_RTCRST# > 0
    VR_ON > 1v
    • mon2
      • Dec 2019
      • 14418
      EC_RTCRST# > 0
      RTC is stuck in reset mode if this signal is a logic '0'.
      • kokono
        • Jun 2018
        • 203
        Thx, What does it mean? And where could the problem be?
        • kokono
          • Jun 2018
          • 203
          Does anyone have any ideas?
          • Sephir0th
            • Oct 2020
            • 1283
            Yeah, double-check the suspicious measurents. From my understanding EC_ RTCRST# can't be low if the board is at least partial working.
            FairRepair on YouTube
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              I beleive EC_RTCRST# will be low . Its connected with N channel Q52. If it is high ,then it will pull down RTCRST. So i think its a false alarm.
              • kokono
                • Jun 2018
                • 203
                Somethings else to measure ?
                • samaelvonhell
                  Acer Nitro 16 AN16-41 motherboard: DAZGUMB1AD0 turns off after 60 seconds
                  by samaelvonhell
                  Hello. Could anyone help me with that problem.
                  Laptop model: Acer Nitro 16 AN16-41
                  It had liquid contact and owner dried it up. Dried it so hard that keyboard is all wavy...
                  I've found one drop on motherboard near B+ capacitor, it wasn't short.
                  But motherboard works exactly 60 seconds and turns it self off. Not overheating just exactly 60 seconds. Normally I would say its ME Region problem, but CPU is AMD...
                  In case im attaching BIOS backup
                  08-01-2024, 08:11 AM
                • zklgfs
                  Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                  by zklgfs
                  I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                  08-11-2025, 02:14 PM
                • twonk9098
                  Lenovo Legion 5 high fan spin turns off after 34 seconds
                  by twonk9098
                  I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                  I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                  I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                  I have tried a few new bios but exactly...
                  07-14-2024, 11:19 AM
                • DanFen
                  Acer Spin 5 - Turns on and off after a few seconds
                  by DanFen
                  I have an Acer Aspire Spin 5 that turns on, displays the Acer logo, and turns back off. This happens in approximately 5 seconds. It won't turn on by itself after that, it stays off.
                  The mainboard is Drift_SKL 16801-1M.
                  I've already tried disconnecting everything, including the battery. I've also removed the CMOS battery for a while, and still no luck.
                  The only thing I could find is that the caps behind the CPU all seem shorted out. If this is the case, would it still display the logo?
                  Other than this, I also noticed that the voltage around the...
                  07-10-2022, 01:56 PM
                • Ludmilaharhordina
                  ACER A315-53G C5V01 LA-E892P rev2A the laptop turns on, but the display does not show
                  by Ludmilaharhordina
                  good afternoon.
                  need help.
                  the laptop turns on, but the display does not show.
                  the laptop came to me from another workshop. visually broken USB 3.0 and soldered BIOS flash drive.
                  I unsoldered USB 3.0 and flashed several different BIOSes, but it did not help.
                  +VCC_CORE 0V
                  +VCC_GT 0V
                  +VCC_SA 1.03V
                  +0.6VS_VTT 0.6V
                  +1.0VALW_PRIM 1.0V
                  +1.0V.VCCSTU 1.0V
                  +VCCIO 1.OV
                  +1.0VS_VCCSTG 1.0V
                  +1.2V_VDDQ 1.21V
                  +1.8VALW_PRIM 1.81V
                  +1.8VS 1.81V
                  +3VLP 3.27V
                  +3VALW...
                  04-02-2025, 08:51 AM
