Searching for NM-B911 power sequence
  • Antonynl
    • Apr 2021
    • 74
    • Nederland
    I can't find the power sequence in the attached schematics and I want to investigate this board because it does not power up but the white led besides the power buttonturns on when power button gets pushed.
  • mon2
    • 14673
    Re: Searching for NM-B911 power sequence
    Review pg 96.
    • Antonynl
      • Apr 2021
      • 74
      • Nederland
      I've seen that but it doesn't provide an explicit sequence?
      • mon2
        • 14673
        No but check the voltage path flow from left to right side. Check each enable pin and respective output voltage to confirm it is present and within range of the specified value.
        • Antonynl
          • Apr 2021
          • 74
          • Nederland
          for now SYSON is not generated on pin107 of the IT8227E :-/
          To me it seems to be a corrupted BIOS with the IT8227E which I never programmed (yet).
          • mon2
            • 14673
            Remove all power -> check the resistance to ground of pin107. If the resistance is not low then yes, it may be the firmware of the noted device.
            • Antonynl
              • Apr 2021
              • 74
              • Nederland
              81K so looks fine. I cant even see a glitch or something on the scope.
              So how do I read and write the bios of this board when the IT8227E contains the bios image?
              • mon2
                • 14673
                Personally do not have the experience in such parts (yet) but it is very possible that the main bios will reflash this component so it is a bit of a catch-22 if the logic board is not booting. Wait on feedback from others.
                From a brief study of this and ENE parts - the parts are often 8051 based and with SPI flash interface.
                • Antonynl
                  • Apr 2021
                  • 74
                  • Nederland
                  I programmed a few Winbond 25Q chips but not these. Indeed catch22 situation: also SIO cant read an image from USB
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3628
                    • slovakia
                    just flash main bios
                    • Antonynl
                      • Apr 2021
                      • 74
                      • Nederland
                      Yes you're right the sio has its own spi memory chip.
                      • Antonynl
                        • Apr 2021
                        • 74
                        • Nederland
                        I don't get a clock on the bios chip U0901 clock pin and also not on pin 105 of the KBC IT8227E.
                        The strange thing is that the led near the power button goes on when the powerbtn is pushed.
                        Is IT8227E toasted for sure or is there another way to test IT8227E kbc?
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • claws77
                          lenovo flex 5 14itl05 power sequence issue
                          by claws77
                          hi guys, my motherboard will not start no matter what
                          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                          but rest nothing happens no sign of life.
                          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                          i have no knowledge of motherboards ....
                          10-20-2024, 02:48 PM
                          03-31-2024, 02:12 PM
