Dell Inspiron 3593 (Not Charging The Battery)
  • mtherana
    • 118
    • South Africa
    Can anyone please HELP.
    I have a Dell inspiron 3593 (FDI55 LA-J081P) REV:1.0 (A00)
    The battery does not charge it Identifies the Chargers 65w and 90w but as soon as I connect the battery it says (AC NOTinstalled and Starts Discharging the battery)at one point it would charge then after 2 min go to IDLE.
    I have tried the following.
    1. Flash with different Bin files
    2. Changed Batteries with known Good ones
    3. changed charging Jack
    DCIN 19v
    PSID 3.0v
    Please Help.
  • mon2
    • 14659
    Re: Dell Inspiron 3593 (Not Charging The Battery)
    Remove all power -> meter in resistance mode -> check the usual 2 x DCin mosfets to see if they are defective or not.
    • lapfix
      • Mar 2020
      • 2764
      • my workshop
      need schematics !
      test PR1 if 33 ohm or not
      • mon2
        • 14659
        need schematics !
        https://www.badcaps.net/forum/showth...light=LA-J081P
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          SDA/SCL present on charging chip?? If you have DSO, check communication on SDA/SCL lines.
          • usyusy
            • Sep 2021
            • 171
            • Pakistan
            sir if the communication shows, does it mean that all charging circuit, i.e its IC, Caps, Resistors, Mosfets are OK or we should explore/test further.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              SDA/SCL communication is just one part of troubleshooting a charging circuit. You simply cant ignore the other aspects. This communication cant rule out other faults.
              • usyusy
                • Sep 2021
                • 171
                • Pakistan
                ok got it sir,.,.regards.
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • lawrenceptrini
                  Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
                  by lawrenceptrini
                  Hi Guys,
                  I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
                  The laptop is working fine with the adapter plugged in and also with a charged battery.
                  Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
                  ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
                  loses its charge, it stays on 0%.
                  Measurements taken
                  Charging IC (ISL95522HRZ) 32 pins
                  Voltage to ground with ac adapter only plugged in:
                  1)...
                  08-26-2024, 06:45 PM
                • danielsak
                  Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
                  by danielsak
                  Hello, I have issue with Dell Inspiron 3542.
                  Motherboard marking:
                  Code:
                  PWB FX3MC REV: A00
                  The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
                  1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
                  1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
                  10-11-2024, 04:36 PM
                • shatteredhalo
                  Dell Inspiron 15 5559 AAL15 LA-D071P battery not charging
                  by shatteredhalo
                  I'm troubleshooting an issue with a laptop where it doesn't seem to want to charge the battery. The laptop will run off the battery alone and use/drain the battery normally in this situation, it will run off the AC adapter alone, and it will run with both charger and battery connected, but it doesn't seem to charge the battery under any circumstance.
                  At startup of the laptop, the following error message is displayed by Dell SupportAssist: "Alert! The AC power adapter wattage and type cannot be determined. The battery may not charge. The system will adjust...
                  08-20-2020, 09:45 PM
                • ipatch
                  dell inspiron 5567 laptop battery lipo WDX0R
                  by ipatch
                  recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
                  1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
                  2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
                  got the computer...
                  04-02-2023, 04:45 PM
