Macbook A2141 820-01700 No Image screen and extern
  • oemelectronic
    • Sep 2019
    • 33
    • peru
    Hello friends
    here reporting after time.
    I have this board 820-01700, it turns on and consumes almost 4 amps but it does not display an image on the screen and also an external monitor
    shift key is activated and the touch bar lights up.
    test with a usb mouse the mouse light comes on.
    is it video?
  • mon2
    • Dec 2019
    • 14677
    Re: Macbook A2141 820-01700 No Image screen and extern
    Does your touch bar display the graphics or only lights up ?
    This model is impacted by FLEXGATE (for the LCD panel) but that does not affect your external display not working.
    If the key caps LED is toggling, the OS is booted.
    • oemelectronic
      • Sep 2019
      • 33
      • peru
      The logo appears for 3 seconds, then a black screen appears, but the machine is still on.
      • mon2
        • Dec 2019
        • 14677
        Check if the graphics are still present on the display with a flashlight / phone in torch mode - shine on the front of the display to view it.
        If yes but is dark, then the fault is with the backlight circuit.
        • oemelectronic
          • Sep 2019
          • 33
          • peru
          Hi
          updated
          It had two failures, screen and board.
          the customer picked up. a lot of expense he said.
          Thanks friends
          • slimmy182
            • Apr 2021
            • 119
            • italy
            Hi there. You mentioned that this model had flexgate issue too. I'm planning to buy one wich is perfectly working on external display and only backlight is not working (you can clearly see image on internal display panel using a torch). That could be both backlight circuit or backlight display flex at this point?. I have not a working display to test in case I decide to proceed and buy.
            • PITERPENY
              Macbook A2141 820-01700 no image
              by PITERPENY
              Hello! A little liquid got onto the 8500 connector, which led to a short circuit in the EDP_INT_AUX_N line in the U9850 . according to the scheme U9850 is identical to the MacBook A1707 820-00928 and I took it from this board and replaced it! (maybe they are not interchangeable? Tell me, otherwise the markings on them are different but according to the scheme they are identical)! I checked the display works on A1707. The cable was replaced and installed from A1707. (as I understand, on A2141 you can install a cable from A1707-A1990, but not vice versa). MacBook works with external display!...
              06-27-2024, 04:55 AM
            • sofles
              Macbook Pro 16" A2141 screen artefacts, kernel panic
              by sofles
              Hi there.
              I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
              I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
              Now situation looks like this, If...
              02-05-2025, 05:05 AM
            • Ugur87
              MacBook Air M4 A3240 Brand New Water Damage no Image
              by Ugur87
              I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
              08-28-2025, 01:09 PM
            • Arshad alam4659
              MACBOOK PRO A2141 SSD SHORT
              by Arshad alam4659
              I HAVE A MACBOOK PRO A2141 820-01700 THIS BOARD IS PP2V5_NAND_SSD1 SHORT TO GROUND THEN I CHECK ONE SIDE U8600 IS SHORT THIS SIDE IS ONLY ONE CHIP U8600 OTHER SIDE
              PP2V5_NAND_SSD1 IS OK AND U9100 U9200 U9300 U9400 IS ALSO OK Will removing the U8600 fix the board or will I have to install a new one
              Link to boardview --> https://www.badcaps.net/forum/troubl...91#post1449091
              10-01-2024, 08:26 AM
            • baglaivlad
              MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
              by baglaivlad
              Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
              Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
              01-09-2024, 09:55 PM
