A1278 820-2879. How is PPV42_G3H generated without charger?
  • xjimx
    • Aug 2022
    • 4
    • Italy
    Hi, I am a beginner, can you help me to understand how is PPV42_G3H generated by the battery without when the charger is not inserted in this particular model? I can't see any direct connection between the battery and U6990 (which generates PPV42_G3H). From the schematic page "Power System Architecture" it would seem that there is continuity between PPVBAT_G3H_CONN and Q7085 but from the schematics and boardview there isn't. Also, from the page "Reverse-Current Protection" it says: "This node is powered through body diodes DCIN through Q7080, PBUS through Q7085 and Q7055". But from the same page there is no connection between that node and Q7055! I also checked with boardview
  • mon2
    • Dec 2019
    • 14691
    Re: A1278 820-2879. How is PPV42_G3H generated without charger?
    U6990 generates the 3v42 rail.
    The VIN of u6990 should have a dual diode with common cathode junction.
    This dual diode accepts power from the external power adapter or ppbus_g3h.
    When adapter is absent, ppbus_g3h will power this 3v42 rail which is now in battery mode.
    • xjimx
      • Aug 2022
      • 4
      • Italy
      Please check the attachments. In this particular schematic there is no dual diode and no connection between ppbus_g3h and u6990
      • mon2
        • Dec 2019
        • 14691
        My bad..this logic board is different. The others will have a dual diode.
        For this case, follow the INTERNAL diodes inside of each mosfets between the battery and the VIN of u6990.
        • xjimx
          • Aug 2022
          • 4
          • Italy
          Perfect, thank you!
          • motormayhem
            Lenovo T460 Only Charges on One Charger
            by motormayhem
            Laptop Question
            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
            05-12-2023, 01:46 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • flat-earther
            how to prevent a connected charger from draining battery when not charging?
            by flat-earther
            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
            So the battery is backfeeding the charger and being drained.
            How can I prevent...
            08-07-2025, 01:04 PM
          • duwane
            MacBook Pro A1278 - No charger light, no PPBUS_G3H, SMC_BC_ACOK short when powered
            by duwane
            Hi All.
            I have a very strange issue that I have been trying to fix for a few days now.
            Model: MacBook Pro A1278
            Logic board: 820-3115-B
            Laptop history:
            No visible liquid damage/corrosion, but found evidence of other rework (flux) so any signs of liquid may have been cleaned. The laptop went in for a battery replacement but wasn't working afterwards and was deemed unfixable (as told to me by previous owner). Not sure if this was by Apple, or another repair company. The flux found was found around ISL6259HRTZ, so can assume it was replaced...
            05-15-2022, 05:22 PM
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
