Need Help With Dell 3542 (No Power)
  • Etterlie
    • Sep 2022
    • 9
    • Latvia
    Hello I have 13269-1 Mother board Rev A00
    Power Switch 2.5v When pressing goes to 0v
    Voltage at the dc plug 19.65 v
    pc4517 - 3.38v , pc4518 - 5.2v voltage jumps in pc4518 5.20v-5.19v
    What else should i check
  • PantherDave
    by PantherDave
    Hi all!
    I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
    05-29-2024, 02:01 PM
  • Mark01
    Dell Optiplex 7490 AIO - red power led after flash
    by Mark01
    Hi guys,
    This is my first post! ๐Ÿš€
    I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
    Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
    07-04-2025, 12:54 PM
  • zlr8r
    Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
    by zlr8r
    hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
    Ill try and give as much info as I can.
    Dell Inspiron 17 (7786) Laptop
    Service Tag: 5J0NHT2
    Bios: 1.9.0
    When I received this , it would only flicker on the KB backlight for a second, then off and on.
    Then it started getting weirder!
    Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
    12-12-2023, 09:31 PM
  • LimesKey
    Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
    by LimesKey
    Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
    10-17-2025, 05:33 PM
