HP 15-ac126nv no power at all
  • harshana
    • Aug 2022
    • 216
    • Sri Lanka
    #41
    Re: HP 15-ac126nv no power at all
    Originally posted by Andreasbest
    I tried it no change, still getting onlily 0.0011A and resistance 1.7kΩ
    you are facing strange things. I have no idea how its possible. anyway have you cleaned all liquid damaged areas with alcohol?? If not first clean the board. Then lets try to start again.
    Edit: If you can heat the board using hotgun I guess some solder points will make a good connection.
    • Andreasbest
      • Aug 2014
      • 1196
      • Hellas ( Greece )
      #42
      Strange things indeed, somebody told me that might be capacitor ready to die.
      Yes all damaged area is cleaned with isopropylene alcohol
      • harshana
        • Aug 2022
        • 216
        • Sri Lanka
        #43
        as I know capacitors should heat up if they defective. Can you heat the board. To make good connection on solder points
        After that, check resistance on PU2 all the pins. If the resistance are okay, sold pu2 and pq7 back and check. I Dont think 1.7kohms allow PU2 to heat up. (according to the calcuations)
        • Andreasbest
          • Aug 2014
          • 1196
          • Hellas ( Greece )
          #44
          Not gonna put the mb to over or resolder everything, not worth the time.
          Any other idea?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            #45
            LDO3 resistance at 1.7K is too low. have you removed the KBC??
            Btw, what is the resistance on PL12 coil??
            • harshana
              • Aug 2022
              • 216
              • Sri Lanka
              #46
              Any other idea?
              I suggested it because I see resistance keep changing. May be contact issues. anyway, then we will have to test all the endpoints who use +3VL
              I saw you have mentioned that you removed a capacitor. Who was that?? Can you remove PC46 (marked in the image) and test resistance again on pin 15.
              Anything changed??
              • Andreasbest
                • Aug 2014
                • 1196
                • Hellas ( Greece )
                #47
                No KBC not removed, only PU2 and PQ7, i'll check resistance Monday because i'm again away from the bench and let you know.
                I only removed the capacitor next to pin15 of PU2 but it's working fine, not shorted.
                I'll try PC46 on Monday and let you know.
                • Andreasbest
                  • Aug 2014
                  • 1196
                  • Hellas ( Greece )
                  #48
                  Hello!
                  Finally found some time to remove KBC.
                  Now resistance @ pin 15 of PU2 is 45ΚΩ and raising.
                  KBC is dead too?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    #49
                    Hello!
                    KBC is dead too?
                    Do i need to confirm that kbc is dead.
                    • Andreasbest
                      • Aug 2014
                      • 1196
                      • Hellas ( Greece )
                      #50
                      So KBC needs programming as you told me so the motherboard goes to donor, can you confirm this at least
                      • harshana
                        • Aug 2022
                        • 216
                        • Sri Lanka
                        #51
                        you will be able to find programmed chip. So I suggest to replace KBC.
                        PS: If you have time,I guess you will be able to use Raspberry or arduino to program KBC. Just an idea. still had no chance to try.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          #52
                          KB series sio used on this mb is definitely programmable and there are pre-programmed chips available in market. So give it a try or else take it to someone who has the tools. KBC programmer is a must if you earn money from this business as almost all the mb has programmable kbc chips these days. I dont know whether raspberry/arduino can program kbc but i think its not possible.
                          • harshana
                            • Aug 2022
                            • 216
                            • Sri Lanka
                            #53
                            Here is the guide I found from youtube. He use CH431a programmer to program KBC.
                            https://youtu.be/GQGH6yZuXCc
                            I was able to flash lot of bios chips using Raspberry pi 3. the software I used was flashrom. Anyway I guess we can use same method to flash KBC.
                            I can guarantee Its possible to flash Bios Chip using Raspberry pi
                            • Andreasbest
                              • Aug 2014
                              • 1196
                              • Hellas ( Greece )
                              #54
                              I have CH431A but i have some questions:
                              A) Where do you get the dump)
                              B) How will i identify a already programmed and a nulled one?
                              On ebay i only see the KBC chips, none mentions "preprogrammed" etc.
                              • Andreasbest
                                • Aug 2014
                                • 1196
                                • Hellas ( Greece )
                                #55
                                [deleted]
                                • harshana
                                  • Aug 2022
                                  • 216
                                  • Sri Lanka
                                  #56
                                  A) You can find them from internet. try to request dump from the bios section of this forum.
                                  B) I see pre programmed chip on Ebay. Mention the KBC No. I will try to share a link
                                    • 21847
                                    NeoProgrammer software for the CH341A .Its better to invest in a proper IO programmer though, as mcplslg123 said "KBC programmer is a must if you earn money from this business as almost all the mb has programmable kbc chips these days."
                                    • harshana
                                      • Aug 2022
                                      • 216
                                      • Sri Lanka
                                      #58
                                      https://www.ebay.com/itm/20290393339...mis&media=COPY
                                      see. you can find the chip if you search
                                      • Andreasbest
                                        • Aug 2014
                                        • 1196
                                        • Hellas ( Greece )
                                        #59
                                        Ok so to summarize: i need PU2, PQ7 and a new KBC, correct?
                                        • Andreasbest
                                          • Aug 2014
                                          • 1196
                                          • Hellas ( Greece )
                                          #60
                                          Ok so i must search for programmed chip for this particular mb, thank you for the info
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            09-06-2024, 05:59 AM
                                            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-12-2024, 02:15 PM
