HP 15-ac126nv no power at all
  • Andreasbest
    • Aug 2014
    • 1153
    • Hellas ( Greece )
    Hi!
    Received a HP laptop today with small liquid damage and cleaned it up with isopropylene alcohol.
    I noticed that PU2 ( RT8243AZQW ) gets extremely hot indicating a shortcircuit, should i replace it right away OR should i check something else first that perhaps causes the short and PU2 is good?
    Schematics attached.
    Thank you!
  • mon2
    • Dec 2019
    • 14065
    Re: HP 15-ac126nv no power at all
    If the part is heating up more than normal then there is a fault.
    Remove all power. Meter in resistance mode.
    Check the resistance to ground of each output voltage rails on this component.
    Post all measurements. If a reading is very low, then need to locate the reason. Perhaps this part is now defective from this event.
    • Andreasbest
      • Aug 2014
      • 1153
      • Hellas ( Greece )
      I remove the PU2 and measure resistance to all pins, all look fine with high resistances to GND 10's ok kΩ except pin 16 that is only 6Ω.
      Is that normal?
      • mon2
        • Dec 2019
        • 14065
        No - that is a very low resistance.
        Remove the capacitor @ PC213 and measure again.
        • Andreasbest
          • Aug 2014
          • 1153
          • Hellas ( Greece )
          There is no boardview available so i removed the capacitor that is connected next to pin 16.
          Short remains on both sides.
          Uploading picture before and after.
          • mon2
            • Dec 2019
            • 14065
            Then remove diode PD202 - make a note of the polarity on the diode for replacement.
            Check again.
            • Andreasbest
              • Aug 2014
              • 1153
              • Hellas ( Greece )
              Could please tag it? I can't find it.
              • mon2
                • Dec 2019
                • 14065
                Post a clear pic of the area - should be black in color and with a band (white stripe) on it.
                • Andreasbest
                  • Aug 2014
                  • 1153
                  • Hellas ( Greece )
                  Found it and desolder it, 7Ω remain on pin 16
                  • Andreasbest
                    • Aug 2014
                    • 1153
                    • Hellas ( Greece )
                    Uploadding pictures of the liquid damaged area, perhaps theey can give us a clue before voltage injecting : )
                    • Andreasbest
                      • Aug 2014
                      • 1153
                      • Hellas ( Greece )
                      I resolder both the cap and the diode and now the resistance is 30Ω
                      How is that possible?
                      • Andreasbest
                        • Aug 2014
                        • 1153
                        • Hellas ( Greece )
                        Plus multimeter doesn't indicate any connection between PD202 and PC213
                        • mon2
                          • Dec 2019
                          • 14065
                          Wait! My bad - have too many open Windows.
                          Let us back track. Keep note of each part that is being removed so you can replace it back. The ECE is not the area of interest.
                          Pin #16 of PU2 is linked to a mosfet device @ PQ8. It should be 8 pins.
                          Remove this dual mosfet @ PQ8 and test the resistance again on pin # 16.
                          Update:
                          In my earlier review - searched for 'PU2' and stopped @ 'PU201' and referenced the pin #16 = REGN pin on it. My apologies.
                          • Andreasbest
                            • Aug 2014
                            • 1153
                            • Hellas ( Greece )
                            "In my earlier review - searched for 'PU2' and stopped @ 'PU201' and referenced the pin #16 = REGN pin on it. My apologies."
                            Sorry but i don't got it, should i procced as you told me with PQ8 or not?
                            • mon2
                              • Dec 2019
                              • 14065
                              Yes - remove PQ8 (8 pin device). Take a picture of the topside for the replacement / pin # 1 orientation.
                              • Andreasbest
                                • Aug 2014
                                • 1153
                                • Hellas ( Greece )
                                With PQ8 removed i get 68Ω
                                • mon2
                                  • Dec 2019
                                  • 14065
                                  Let me understand where we are at...
                                  you have PQ8 removed ?
                                  you have PU2 removed ?
                                  but you are measuring 68 ohms to ground on pin #16 of the PU2 pcb pad ?
                                  This is not a good reading. The reading should be OL since there is nothing on pin # 16 of PU2 if it is removed.
                                  Can you confirm the details ?
                                  • Andreasbest
                                    • Aug 2014
                                    • 1153
                                    • Hellas ( Greece )
                                    Exactly.
                                    PQ8 and PU2 removed now, resistance between pin 16 and GND = 64Ω
                                    • mon2
                                      • Dec 2019
                                      • 14065
                                      That does not sound right - is the posted schematic 100% for your laptop ?
                                      • Andreasbest
                                        • Aug 2014
                                        • 1153
                                        • Hellas ( Greece )
                                        Just found the mistake
                                        I count the pins clockwise while they are counter clockwise like usual.
                                        I'm terribly sorry for this.
                                        The correct pin is 15, not 16 : (
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
                                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:15 PM
