a1707 820-00281 no power stuck at 5v
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    Re: a1707 820-00281 no power stuck at 5v
    first time after the replecement i got 200ma 5v ..... getting crazy.....
    • mon2
      • Dec 2019
      • 14023
      1) What is the voltage of PP3V3_G3H @ L6900, pin #2 ?
      2) What is the voltage of PPBUS_G3H @ fuse F7000 ?
      • lordgeny
        • Apr 2016
        • 223
        • Italia
        Originally posted by mon2
        1) What is the voltage of PP3V3_G3H @ L6900, pin #2 ? 3.4
        f7000 0.90v
        • mon2
          • Dec 2019
          • 14023
          2) remove the fuse @ F7000. Test the voltage of ppbus_g3h at the pcb pad of F7000, pin #1. Post the reading.
          • lordgeny
            • Apr 2016
            • 223
            • Italia
            l6900 pin 2 3.40v
            f7000 pin 1 no voltage
            • mon2
              • Dec 2019
              • 14023
              What is the voltage at R7060 ?
              • lordgeny
                • Apr 2016
                • 223
                • Italia
                #27
                r7060 no voltage
                • mon2
                  • Dec 2019
                  • 14023
                  Meter in DIODE mode. No power to the board.
                  Check the diode readings to ground of F7000, pin #1 in both directions.
                  Post the readings.
                  • lordgeny
                    • Apr 2016
                    • 223
                    • Italia
                    #29
                    0.380
                    • lordgeny
                      • Apr 2016
                      • 223
                      • Italia
                      #30
                      without fuse i have pin 2 0.380 pin 1 0.480
                      • Arshad alam4659
                        • Aug 2020
                        • 156
                        • India
                        #31
                        i have 820-00928-A stuck at 5v on USB. I measured some volt
                        PP20V_USBC_XB_VBUS = 5v
                        PP3V3_UPC_XB_LDO = 3.3v
                        PP1V8_UPC_XB_LDOA = 1.8v
                        PP1V8_UPC_XB_LDOD = 1.8v
                        PP1V1_UPC_XB_LDO_BMC = 1.1v , sometime fluctuate to 0.6v no sorting
                        PPDCIN_G3H = 5v
                        i change cd3215 but nothing change anyone suggest me the solution
                        • mon2
                          • Dec 2019
                          • 14023
                          The ldo voltage for the bmc should be stable. Check the CCx contacts. Check their measurements in diode mode. No power. Meter in diode mode. Red probe to ground. Black probe to the CCx line. Test each cd3215 this way. The CCx lines communicate the power delivery contracts where default is 5 volts on power up.
                          • Arshad alam4659
                            • Aug 2020
                            • 156
                            • India
                            #33
                            one cd3215 is bad i removed cd3215 but 20v not generate what next step
                            • Arshad alam4659
                              • Aug 2020
                              • 156
                              • India
                              #34
                              can you suggest me
                              • mon2
                                • Dec 2019
                                • 14023
                                Which cd3215 was bad on the board?
                                Has this bad cd3215 been replaced with a known good part?
                                which exact cd3215 was used for the replacement?
                                soldering ok?
                                Each cd3215 must be onboard as they function in a master & slave relationship.
                                what is the voltage to ground now of ppbus_g3h?
                                see this article here:
                                https://logi.wiki/index.php/CD3215_Bootup_Sequence
                                • Arshad alam4659
                                  • Aug 2020
                                  • 156
                                  • India
                                  #36
                                  soldering ok?
                                  PPBUS_G3H =0v
                                  i read this artical and 1 to 11 sequence all ok but 12 sequence is 20v but 20v not generate
                                  i dont understand what missing volt
                                  if i injected 5v on ppbus_g34 ampare is 0.0065
                                  • mon2
                                    • Dec 2019
                                    • 14023
                                    PPBUS_G3H =0v
                                    Remove all power. Meter in resistance mode. Measure the resistance to ground of PPBUS_G3H.
                                    Post the measurement.
                                    • Arshad alam4659
                                      • Aug 2020
                                      • 156
                                      • India
                                      #38
                                      PPBUS_G3H = OL
                                      • Arshad alam4659
                                        • Aug 2020
                                        • 156
                                        • India
                                        #39
                                        left side 2 cd3215 and right side 2 cd 3215 if i soldered one side 2 cd 3215 all ldo ok but i soldered seacond side cd 3215
                                        ldo flactuate 2.5 to 3.3v and PP1V1_UPC_XB_LDO_BMC = 0.6 to 1.1 and also flactute PPDCIN_G3H =3.1 to 5v but one side no flactuate volt in stable
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
