HP 15-dc1002tx DAG3DCMBCC0 REV C red blink on power button
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    hi all,
    i have a problem with HP Omen 15-dc1002tx DAG3DCMBCC0 REV C that has red blink only on power button.
    after that i checked fot short and found 1 caps is shorted. took it off and tried to power on. now still red blink but with 5 short 3 long white blink on caps lock.
    already reprogram bios but still the same..
    after that i check again there is still short, injected voltage but can not find the source.
    does anyone have schematic and boardview for this type?
    thanks in advance.
  • themosttogain
    HP Envy 13-BA1565na with intermittent power button
    by themosttogain
    Hope someone can give me some suggestions on this because i'm at my wits end with it...
    I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
    Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
    07-12-2024, 03:03 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    03-31-2024, 02:12 PM
  • OOF DIO
    ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
    by OOF DIO
    (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
    (Had 3 problems, now just 1)
    I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
    I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
    I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
    04-19-2025, 05:03 PM
  • dfear
    HP 14-bf054sa - weird power button issue
    by dfear
    - forum postHP 14-bf054sa
    LA-F301P Rev 1.0
    This laptop came in with a number of minor issues (Screen with black bar and battery that needs replacing). The laptop also had issues relating to salt (water/air) corrosion, having been used near the ocean.
    The HDMI port, 2x usb ports and the SD card reader all needed replacement as they had been affected by salty air and only work intermittently. The HDMI port, 2x usb ports and the SD card reader have been replaced and have been checked for (obvious) shorts.
    The laptop now fails to turn on (normally)....
    09-24-2021, 09:33 AM
