HELP Identifying a MOSFET L3 GUD
  • silver60618
    • May 2021
    • 39
    Hi Gang, Im working on an Acer Aspire 5, that wasnt charging or randomly not powering on. I identifyed a shorted MOSFET and removed it. Laptop now powers on with the Missing MOSFET.
    Im having a devil of a time finding a replacement. the value of mosfet reads L3 GUD 4U0T01. I cannot find anything on this online
    Is there a subsitute I can use? can I grab a similar sized one from a donor board of another brand?
    Thanks!
  • mon2
    • 14859
    Re: HELP Identifying a MOSFET
    Which location ? Yes, it is an Acer so any replacement part will improve the operation.
    Most of the mosfets can be replaced with others from Digikey / Mouser / Arrow / Aliexpress, etc. (or even donor boards).
    Can you link the schematic if on this forum ?
    • piernov
      • Jan 2016
      • 4439
      • France
      Unikc pe5e6ba
      • silver60618
        • May 2021
        • 39
        Re: HELP Identifying a MOSFET L3 GUD
        Thanks Guys! I was able to replace the 2nd power mosfet that was shorted from a donor board and all is good now!
        Cheers!
        • redbaron1007
          Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
          by redbaron1007
          I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
          Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
          09-09-2025, 11:10 AM
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • boardbread
          Identifying MOSFET "03 GUB 7X1V03" or "02 GUA 6X4H06"
          by boardbread
          Hello! I have these MOSFETs used on a desktop motherboard, the name of the motherboard will not be helpful, because it is quite rare and doesn't have schematics. They are used in a power rail and have very unusual metallic package, I've never seen anything like this. Could you help me identifying these, or at least identify their package?
          12-24-2024, 10:26 AM
        • kingis85
          Asus rog flow gz301v mosfet ic identifying
          by kingis85
          Here i have asus rog flow, super powerfull and expensive tablet. The problem is that it only works with a battery. The owner had it plugged on and his dog wanted to put his teeth on the usb-c plug and well.....
          So after that it is not charging with a new asus official charger. I opened and tried to find something burned with microscope but everything looks good. I did not found any short. I did see that it does not try to take any power with usb meter, so the 5v line must be open somewhere. This board is really hard to make any sense because i can not find any kind of data sheet or info....
          11-20-2023, 05:50 AM
        • Nooy
          VGA MOSfet permanently shorted and loss of MOSfet pad
          by Nooy
          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
          02-14-2024, 02:26 AM
