Identifiyng a component on board MSI - MS-17FK : Bravo 17 A4DDK
  • DominikPechac
    Still learning
    • Jan 2019
    • 7
    • Czech Republic
    I'm begging for help on this one. A customer came with a laptop that has a broken screen. I also checked the board and found a blown component on the board. I assume it has something to do with the backlight because even the broken screen has no backlight. Otherwise, the laptop works fine on the external screen.
    Can someone help me with identifying the blown component? I wasn't able to find a schematic for this motherboard or find the right IC from the marking on it.
    Thanks, everyone! Have a great day.
  • JaroTech
    • Mar 2015
    • 351
    Re: Identifiyng a component on board MSI - MS-17FK : Bravo 17 A4DDK
    Hi, I think it's an APL3512ABI-TRG.
    • mon2
      • Dec 2019
      • 14201
      +1
      Nice find! Looks to be a logical device and the markings do match - these are common to being used for USB connectors so there should be plenty of equivalent devices on the market.
      Review DIODES Inc. or similar. 'USB Load switch' with a 2A rating, etc. but must be ACTIVE HIGH for the enable pin. SOT23-5 package.
      • DominikPechac
        Still learning
        • Jan 2019
        • 7
        • Czech Republic
        Hello, thanks a lot! Bought it from eBay and that fixed the problem. Listing on eBay: 5PCS New APL3512ABI-TRG APL3512ABI APL3512A sot23-5 L2A* L2AB LA24 L2A6 IC CHIPS
        • BalkanBoy
          • Feb 2017
          • 69
          • Croatia
          In such cases I take 1st similar donor board and change without reading markings when you see it's definitely backlight driver, never had any issues so far.
          • cmlewis89
            LG 47LB5DF blown power supply board
            by cmlewis89
            Hi folks,
            I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
            09-03-2024, 07:50 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
