Dell inspiron 3593 Charging Fault
  • Indunil555
    • Jul 2021
    • 17
    • Sri Lanka
    Dell inspiron 3593
    FDI55 LA - J081P Motherboard
    Rev 1.0
    Laptop Battery not charging.
    Laptop work only battery power.
    Adaptor connected ( 19v DC Jack) Motherboard main voltages ok but no display and not charging.
    One time white led and 3 time orange led blinking continue.
    Charged battery install after laptop power on and display ok.
    What is the problem ?
    How to fix it ?
  • mon2
    • Dec 2019
    • 14210
    Re: Dell inspiron 3593 Charging Fault
    Are you using the original and recommended power adapter for this laptop?
    This is important as the logic board checks for a special ID that is extracted from the power adapter over a single wire communication for a valid match. If the adapter is not suitable or the ID check fails, this may be the result.
    If ok, the 19v should power the logic board.
    You may have defective DCin mosfets. This is a common fault. Link or post the schematic for this logic board. Have not checked my database for the same.
    Remove all power. Check the resistance across the mosfet pins.
    Source & drain
    Source& gate
    Gate & drain
    Post the measurements. Then repeat for the next DCin mosfet. Also share the charger IC markings near this mosfet area. Likely to be the "BQ" series from TI (not the rapper).
    • mon2
      • Dec 2019
      • 14210
      Found the schematics.
      See attached.
      Remove all power -> meter in resistance mode.
      Check the resistance across the 2 x DCin mosfets as follows:
      source (1-2-3) & drain (5-6-7-8) ; pick any pin from the group
      source (1-2-3) & gate (4)
      gate (4) & drain (5-6-7-8)
      Post the measurements and the scale used on your meter.
      Repeat for PQB11 and also PQB12.
      • Indunil555
        • Jul 2021
        • 17
        • Sri Lanka
        See attached.
        Mosfet are ok
        checked.
        • mon2
          • Dec 2019
          • 14210
          Post the resistance readings.
          • Indunil555
            • Jul 2021
            • 17
            • Sri Lanka
            post the resistance readings.
            pqb11
            s-d 4.1mΩ
            s-g 3.6mΩ
            d-g 8.7mΩ
            pqb12
            s-d 2.5mΩ
            s-g 3.6mΩ
            d-g 8.4mΩ
              DELL Inspiron 15 3593 Notebook 3000 Specification for Upgrade or Repair
              This specification for the DELL Inspiron 15 3593 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 3593 boardview and 15 3593 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron...
              09-06-2024, 11:48 AM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
            • lawrenceptrini
              Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
              by lawrenceptrini
              Hi Guys,
              I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
              The laptop is working fine with the adapter plugged in and also with a charged battery.
              Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
              ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
              loses its charge, it stays on 0%.
              Measurements taken
              Charging IC (ISL95522HRZ) 32 pins
              Voltage to ground with ac adapter only plugged in:
              1)...
              08-26-2024, 06:45 PM
            • Indunil555
              by Indunil555
              Dell inspiron 3593
              Rev 1.0
              How to fix it ?
              09-12-2022, 09:28 PM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
