Dell inspiron 3593 Charging Fault
  • Indunil555
    • Jul 2021
    • 22
    • Sri Lanka
    Dell inspiron 3593
    FDI55 LA - J081P Motherboard
    Rev 1.0
    Laptop Battery not charging.
    Laptop work only battery power.
    Adaptor connected ( 19v DC Jack) Motherboard main voltages ok but no display and not charging.
    One time white led and 3 time orange led blinking continue.
    Charged battery install after laptop power on and display ok.
    What is the problem ?
    How to fix it ?
  • mon2
    • 14595
    Re: Dell inspiron 3593 Charging Fault
    1) review the charger IC @ PUB01.
    2) measure the voltage on each pin of the 2 x DCin mosfets (PQB11 & PQB12)
    source (1-2-3)
    gate (4)
    drain (5-6-7-8)
    Post each measurement.
    Repeat for each mosfet.
    If all is well, the GATE voltage has to be high enough to enable the above 2 x mosfets to pass the DCin voltage to power the lower board.
    3) if the voltage is not high enough, then with great care, measure the voltage on each pin of the charger IC. Do so with caution to not short any of the pins which can cause other damage to the charger IC and then will have to be replaced.
    Post each voltage measurement in a table with each pin.
    As per the flood of other posts on this forum - the issue is often with the DCin mosfets - see the detailed sticky from @Piernov above for more information.
    • Indunil555
      • Jul 2021
      • 22
      • Sri Lanka
      pqb11
      s-d 4.1mΩ
      s-g 3.6mΩ
      d-g 8.7mΩ
      pqb12
      s-d 2.5mΩ
      s-g 3.6mΩ
      d-g 8.4mΩ
      • mon2
        • 14595
        1) resistance is fine.
        2) proceed to test the voltage measurements noted in the post.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Voltage on SDA/SCL present on battery connector??
          • master3112
            by master3112
            07-29-2025, 01:55 PM
            DELL Inspiron 15 3593 Notebook 3000 Specification for Upgrade or Repair
            This specification for the DELL Inspiron 15 3593 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 3593 boardview and 15 3593 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron...
            09-06-2024, 11:48 AM
          • lawrenceptrini
            Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
            by lawrenceptrini
            Hi Guys,
            I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
            The laptop is working fine with the adapter plugged in and also with a charged battery.
            Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
            ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
            loses its charge, it stays on 0%.
            Measurements taken
            Charging IC (ISL95522HRZ) 32 pins
            Voltage to ground with ac adapter only plugged in:
            1)...
            08-26-2024, 06:45 PM
          • Indunil555
            by Indunil555
            Dell inspiron 3593
            Rev 1.0
            How to fix it ?
            08-24-2022, 04:08 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
