ASUS X555DG strange lcd flickering
  • julianmustofa
    • Dec 2021
    • 39
    • indonesia
    Hi all i've been troubleshooting a strange flickering lcd on asus x555dg
    It only happen when using battery power.
    At first i tought it was the battery. Because the battery indeed in bad swolen condition.
    I buy new battery. Test it and same result. I can confirm the new battery is fine.
    And then I put another lcd (different type) and it was working fine on this laptop.
    So you maybe tought the original lcd is faulty.
    No it is not. I tested the original lcd on the other laptop and it just working fine. No flickering at all even using battery power.
    I have no idea what is going on here. Wether is the board or the lcd it self was faulty?
    Any advice?
    Original screen- Innolux N156BGE-E42
    Another screen- BOE HB140WX1-301
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: ASUS X555DG strange lcd flickering
    There are several posts on this forum with the same issue. Just replace the coil marked "100" on the screen logic card. Its located near to backlit controller on the screen. This is a known issue. Coil should be an exact one and you can get them from any defective screen.
    • julianmustofa
      • Dec 2021
      • 39
      • indonesia
      Replaced the coil that you mentioned. And it works now. Thanks for valuable information
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • dhenion
        Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
        by dhenion
        I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
        The original board was:
        ASUS X510UNR REV 3.0 A
        The replacement board is:
        ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
        It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
        01-30-2024, 01:45 PM
      • rob777
        Asus TUF won’t run off battery
        by rob777
        I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
        I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
        Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
        Thanks....
        05-27-2025, 07:07 PM
      • Iherduleikgemz
        Asus FX505DY - Battery not charging - BQ24780S
        by Iherduleikgemz
        Hello everyone
        I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
        I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
        01-13-2025, 03:54 PM
