HP Elitebook 840 G3 stuck on windows loading
  • dimah77
    • Sep 2016
    • 149
    • ALGERIA
    HP Elitebook 840 G3 power on but stuck on windows loading, even from Live USB, accessing BIOS normally , bios flashed with safe Clean Me Version, but still having same issue ... CPU problem ?
    Motherboard P/N 6050A2892401-MB-A01
  • loopster
    • Sep 2020
    • 80
    Re: HP Elitebook 840 G3 stuck on windows loading
    What about a Linux Live Distro? UEFI or Legacy/CSM?
    • dimah77
      • Sep 2016
      • 149
      • ALGERIA
      Same issue with UBUNTU LIVE and GPARTED LIVE both LEGACY or CSM
      • Kambi13
        • Aug 2022
        • 134
        • Portugal
        Have you tried to change the SDD/HDD. Also with different Ram Dimms?
        • mon2
          • 14730
          or even try to boot from a USB media using FreeDOS -> check the RUFUS tool which offers this support.
          Does FreeDOS boot ok on your box ?
          • mosfetratus
            Sure Not
            • Feb 2019
            • 174
            • Resistron
            media should be formatted for legacy or uefi, won't work for both.
            • piernov
              • Jan 2016
              • 4439
              • France
              Modern Linux LiveUSB images can typically work on both legacy BIOS and UEFI, as long as it's written properly to the USB drive of course with no tools messing with the bootloader.
              • dimah77
                • Sep 2016
                • 149
                • ALGERIA
                Multiboot tool VENTOY can do this,
                I tried all methods ... boot only on DOS interface ... when trying graphic it stuck ... most likely PCH problem
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  Can try to boot Linux with the following kernel parameters kernel parameters to disable CPU power savings and GPU acceleration and show information messages:
                  Code:
                  idle=poll nomodeset modprobe.blacklist=i915 nosplash verbose
                  • Zibbo
                    • Mar 2017
                    • 205
                    • Zimbabwe
                    I would check VCore for glitches with a DSO
                    • dqtech
                      MSI GL63 8RD stuck after windows loading
                      by dqtech
                      in bios setup this laptop was running ok....but when boot to windows, will stuck like this after windows loading....i've try change another ssd and try to reinstall windows but this problem still persist...ampere also drop from 2amp (at windows loading) to 0.8a (when stuck).....any help?...
                      07-07-2023, 06:51 AM
                    • jheunne
                      asus ux425I help only loading windows bsod
                      by jheunne
                      i have here asus ux425i problem won't boot on windows even installing new clean windows it just loading windows long time then turn to bsod even the installer unable to access on startup. new ssd new installer same status. i already flash bios no luck have anyone encounter this problem
                      02-03-2025, 11:28 PM
                      HP EliteBook EliteBook 850 G3 Notebook PC (ENERGY STAR) Notebook 800 Specification for Upgrade or Repair
                      This specification for the HP EliteBook EliteBook 850 G3 Notebook PC (ENERGY STAR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 850 G3 Notebook PC (ENERGY STAR) boardview and EliteBook 850 G3 Notebook PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                      09-06-2024, 05:33 AM
                    • japlytic
                      DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                      by japlytic
                      In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                      Tried (only with keyboard/mouse connected):
                      • BIOS + database update
                      • Using latest Windows 11 image built with official image creation tool
                      • Previous setup version for Windows 11 installer
                      • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                      • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                      • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                      06-19-2025, 04:59 PM
                    • B83C
                      HP elitebook x360 1040 G5 Stuck at 'Entering setup menu...'
                      by B83C
                      Received a faulty HP elitebook from my friend that does not boot up properly. The internal display is broken, so the only way to view the display output is via hdmi. However, when booted up the screen get stuck with 'Entering setup menu...' when esc is pressed upon booting. HP logo isn't displayed on bootup, only black screen, but an underscore cursor appear on top left corner of the screen. Has anyone any idea what could be the culprit here? I have flashed both the EC and BIOS flash but to no avail. The serial number is 5CG9377GCT, and below is the original flash content:
                      Also the...
                      02-03-2025, 08:28 PM
