I have hp gaming board DAG3JBMB8D0 the problem is when i press power button dc jack light blinks 3 times white. It has bq738 charging ic i found acdet 2.1v after changing resistor the voltage is 2.8v but same problem. Acok is 3.2v and the board has 3v and 5v.
DAG3JBMB8D0 HP 3 times blink
by BachPhi
- Issue:
Notebook blinks 5 times on power-up and does not boot.
Actions Taken:- Tried multiple reset key combinations: V, B, Win, Win+V, Win+B.
- Removed and inspected all components on the mainboard (Part No. DA0X8JMB8E0).
- Replaced the RTC battery (CR2016W).
- Swapped in a different RAM module.
- Checked the BIOS chip (Winbond 25Q128JVSQ):
- Measured Vcc = 3V
- /CS signal stays high after power-on (no activity).
- Issue:
by AdrenalinTLI am sitting with a very similar issue.
Basically, had a probook that worked, gave it to someone, they returned it DOA. what the heck happened, I have no idea.
Caps and num lock blink 4 times, as per HP, thats a board failure. I am very new to this, so perhaps I should be posting a new thread?
Anyway, I resoldered the bios chip on after trying EVERYTHING else including reseating ram, cpu etc.
Multimeter shows 19.5V on power, so I presume thats correct. Fan spins, no display. No post. Bios chip looks good from what I can tell just not sure how... -
by Smartec82Hi,
I have this tv that works for about 15 to 20 minutes and then turns off, leaving the led to blink 8 times, this via HDMI, because I can't get into the tuning menu, it says Function unavailable.
Through the manual, I was able to verify that it could be a software problem, but unfortunately the tv already has the latest software and that's why it won't let me update.
Does anyone know of a way to reinstall the software? -
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM -
by EazyBoneI write this to maybe help another with this TV.
So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
...03-18-2024, 10:24 PM - Loading...
