HP 350 G1 with charging related issues, need help!!!
  • classicandy
    • Apr 2018
    • 309
    • Nigeria
    Hi, I have this HP 350 G1 that gives out about 16.8v on the battery (+) terminal in the battery connector on the motherboard WITHOUT a battery inserted. It should be around 2.8v without battery inserted. The battery charger IC is BQ728.
    I have searched online but haven't found the schematic diagram yet. HP 2000 uses same battery charger IC, so its schematic diagram can work for it in terms of its charging circuitry.
    I have attached the schematic diagram for HP 2000 as well as images of the charging section of the HP 350 g1.
    I would be very grateful for your help.
  • classicandy
    • Apr 2018
    • 309
    • Nigeria
    Re: HP 350 G1 with charging related issues, need help!!!
    I have tried replacing the battery charger IC (BQ728) but no luck
    • mon2
      • Dec 2019
      • 14681
      Remove all power.
      Meter in resistance mode.
      Check the resistance of the mosfets linked to the battery.
      Source (1-2-3) & drain (5-6-7-8)
      Source & gate (4)
      Drain & gate
      Start with Q6012 which is the battery mosfet. Post the measurements.
      • classicandy
        • Apr 2018
        • 309
        • Nigeria
        Originally posted by mon2
        Remove all power.
        Source & gate (4)
        Drain & gate
        Ok, thanks for the fast response. I'm taking readings now
        • classicandy
          • Apr 2018
          • 309
          • Nigeria
          Remove all power.
          Source & gate (4)
          Drain & gate
          Q6012
          Resistance Mode (200M ohms)
          Drain & Gate
          Black Probe on Gate/Red on Drain = 3 ohms
          Red Probe on Gate/Black on Drain = No readings, probably above 200M ohms
          Gate & Source
          Black Probe on Gate/Red on Source = No readings, probably above 200M ohms
          Red Probe on Gate/Black on Source = 2.8 ohms & dropping, (slows down around 2.5 ohms)
          Source & Drain
          Black Probe on Source/Red on Drain = 2.71 ohms (dropped from 3.01)
          Red Probe on Source/Black on Drain = 2.05 ohms
          • mon2
            • Dec 2019
            • 14681
            Can you share or confirm the readings ? Post the pic of your meter to verify.
            200M = 200 Mega ohms is the max.
            If '3' reading, then it is 3 Mega ohms ? That is ok if understanding is correct.
            Check the next mosfet in the same way for the high side charging leg for the battery.
            • classicandy
              • Apr 2018
              • 309
              • Nigeria
              I think it is 3 Mega ohms
              Also, I just noticed, It goes to 16.9v (from 2.3v) when powered on without battery inserted and goes back to 2.3v after some seconds when powered off.
              • classicandy
                • Apr 2018
                • 309
                • Nigeria
                I have checked another motherboard using same battery charger IC (BQ728) and it doesn't behave like this.
                Is it normal for this HP 350 g1 to behave differently despite using same battery charger IC with other motherboard ?
                • classicandy
                  • Apr 2018
                  • 309
                  • Nigeria
                  The laptop behaves in a weird way such that if i power it on, it will work well for some time like few minutes and might trip off, and if i try to power it back on, it might turn on and turn back off almost immediately and the white light would go off as well, until i unplug the charger and leave the motherboard for a while (probably to cool down) and try to power it on again before it comes on for some time.
                  It doesn't get too hot when on. Its just normal operating temperature, so i can't suspect its due to overheating
                  • mon2
                    • Dec 2019
                    • 14681
                    Carefully measure the voltages on each pin of the charger IC.
                    It is possible that the charger IC believes there is a battery connected so it is enabling the charging mosfets.
                    • coasterghost
                      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                      by coasterghost
                      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                      System Hardware:
                      Processor: AMD Ryzen 7 PRO 5850U
                      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                      09-08-2025, 10:46 PM
                    • twonk9098
                      Leovo Thinkbook 14 G2 ITL - Charging issues
                      by twonk9098
                      I have 2 x Lenovo Thinkbook G2 ITL laptops. They seems to be identical specs, both 11th gen, 1135G7 cpu, both 12gb ram and both 256gb M.2 ssd.
                      I have ensured both have the same latest bios and ec firmware.
                      One of them works totally fine however the other has charging issues.
                      I have compared both motherboards in diode mode and cannot find much of a difference anywhere.
                      I have swapped the motherboards over to the other casings and the issue transfers.
                      It's behaviour is it will connect at 20v on USB-C and always start to charge....
                      04-07-2025, 05:17 PM
                    • Aimbit
                      A few Gen 3 iPads with differing charging issues (A1403, A1430, A1416) & iPad Air 2 (A1566)
                      by Aimbit
                      I purchased some broken iPads (non-charging), trying to repair something a little trickier than retro consoles... I have all the necessary tools.
                      A1430 - Draws 930mA consistent, screen is black with red/empty battery icon, no charging symbol.
                      A1403 and A1416 - Draw 930mA, wait 3 seconds, dip to 0, repeat.
                      A1566 - Similar to the previous issue, it draws some power for a few seconds, then resets my ammeter, and repeats. Waiting for my lightning port tester to come to check the tristar.
                      Seeing as these are old, and likely have been dead for ages, is a battery...
                      05-23-2024, 06:36 PM
                    • badboyzzz
                      A2229 ipad pro 12.9 4gen strange problem Logic Board related charging but no usb data
                      by badboyzzz
                      I have a strange problem with my iPad Pro 12.9 4Gen / A2229. When I start the device, it stays on the Apple logo, but when I heat the back of the device with a hair dryer, the device boots, but this time there is an interesting problem. The iPad is charging, but there is no USB data on the computer. The USB charging port has been changed and the chips seem normal, but I have given it to 2 different Apple services in Latvia, but the repair could not be done. Is there anyone who can help with this? Can someone support the repair by sending only the motherboard within Europe? Thank you.
                      12-28-2024, 02:11 PM
                    • Scoff
                      HP Probook 470 G4 - Power and Charging Problem
                      by Scoff
                      Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                      Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                      07-03-2023, 09:28 AM
