Need Help Identifying Component - iPad Pro 12.9" 3rd Gen
  • grimacelord
    • Jan 2017
    • 379
    Hello. I am troubleshooting an iPad Pro 12.9" 3rd Generation for no touch. There is a component that has a visible burn mark on it that needs to be replaced, but I cant seem to find what it is.
    The component is called Q2201 in ZXW Tools. Can anyone identify this component?
  • mon2
    • Dec 2019
    • 14170
    Re: Need Help Identifying Component - iPad Pro 12.9" 3rd Gen
    What is the 820-xxxx of your logic board ?
    • grimacelord
      • Jan 2017
      • 379
      Originally posted by mon2
      what is the 820-xxxx of your logic board ?
      820-01435-a
      • mon2
        • Dec 2019
        • 14170
        So far, see only the attached bv.
        • grimacelord
          • Jan 2017
          • 379
          Thanks for the reply. Yeah, that's basically all ZXW Tools tells me as well.
          I would try and read the markings on the component itself, but because of the burn mark, I can't make out what they say.
          If someone has a logic board for this model and would be kind enough, could you take a look at the component and see what the markings are?
          • grimacelord
            • Jan 2017
            • 379
            Update: Luck would have it that another customer brought in the same iPad model for a screen replacement, so I took the shield off and took a look at their component.
            It is marked, "FP G3" or "G3 FP", I guess. Attached is pic. Hopefully this helps someone?
            • GeirAndersen
              iPad .pcb file collection
              by GeirAndersen
              I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
              Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
              IPAD COLLECTION 1
              +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
              +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
              +---iPad mini3 820-00008(A1599) 820-00002(A1600)
              +---iPad mini4 820-00180(A1538) 820-00177(A1550)
              +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
              +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
              12-09-2024, 09:28 AM
            • Papa Gleb
              Ipad 5 (2017 A1822) Need help identifying component
              by Papa Gleb
              Hello all,
              I have an ipad 5 that came in for home button repair. Issue fixed and return to the customer who then stated it also has battery/charge issues. The battery seemed fine however the ipad would acknowledge the charger every other time. The port looked fine but considering that it would work than not, I decided to change the port. Port changed and yet it draws zero amps. Removed the shield and found this burned component. Tried to find a board view but seems like the ipad 5 is the only ipad for which board views don't exist.
              Yes I should have definitely done...
              04-18-2022, 05:18 PM
            • grimacelord
              Apple iPad Pro 3rd Generation 12.9" (A1876) No Power/Charge When Screen Is Connected
              by grimacelord
              Hello.
              Working on an Apple iPad Pro 3rd Generation 12.9" that has a weird issue. When the display is NOT connected, the iPad will charge and power on normally. I know it's on because I can hear notification sounds and the charging notification sound.
              If I connect a brand new display to the logic board, the iPad will not turn on at all. When I connect the iPad to an 18W wall charger and a USB-C ammeter, I can see that the iPad is attempting to charge, but constantly "resets" after just a moment or two.
              For example, when I connect the iPad to...
              04-15-2022, 11:06 AM
            • trepachka
              iPad Air A1475 Boot loops after replacing battery
              by trepachka
              This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
              The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
              I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
              11-08-2024, 03:17 PM
            • ipatch
              ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
              by ipatch
              i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
              08-24-2024, 02:36 PM
