Macbook 820-2849 c7404 - Capacitor Replacement
  • mikay786
    • Aug 2014
    • 765
    Just looking for a suitable capacitor to replace C7404 on a 820-2849 macbook pro 17" logic board. 62uf 11v Case B2 (tantalum?)
    Found these on ebay, are they suitable?
    https://www.ebay.co.uk/itm/165488307...4AAOSwTgNihRXG
    also how bad is it if a cap is blown / short on the PPBUS_CPU_IMVP_ISNS line?
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Macbook 820-2849 c7404 - Capacitor Replacement
    Used random SMD tantalum capacitors for £3.50 each? That's a total ripoff. Take one off of a donor board yourself, or ask your local electronics supplier for a new one.
    • mikay786
      • Aug 2014
      • 765
      Don't have any donors, I can't seem to find anything new in 62uf 11v
      Would a 68uf do?
      • mon2
        • Dec 2019
        • 14117
        Yes. Just be sure the voltage of the capacitor is equal or higher than the original.
        • mikay786
          • Aug 2014
          • 765
          https://uk.rs-online.com/web/p/tanta...citors/6844200
          Is that ok?
          • mon2
            • Dec 2019
            • 14117
            See attached.
            1) In my opinion, if you remove this cap and use as-is without this part, the logic board will function fine. There are many caps on this rail so the lack of 62uf (or similar) will not be missed.
            2) See the schematic to note that the CASE B2 is referenced. The case code defines the x * y dimensions. The height may matter on some logic boards but it should not be an issue here. The height of the part is not going to stop the mounting of the casing / lid / keyboard of the unit.
            Best if you can find a capacitor, if you really wish to replace it, 68uF 20V or higher voltage is fine but must be CASE B2.
            My bad...this rail is mating with PPBUS_G3H = ~13 volts peak so select a cap with a higher voltage !! NOTE MY ERROR and correction.
            3) The referenced part in your last post is too large and the ends (solder tabs) will not land properly on your logic board. From your shared pic - the space is limited on the logic board so remain with CASE B2 style.
            Let me have a quick look for a suitable part...
            Update:
            Search for the following keywords 'tantalum B2' -> this will define the physical size you have on the logic board.
            Then choose any cap that is > 11 volts since the schematic references this as a suitable cap voltage.
            On this logic board (A1297) - the PPBUS_G3H rail must be under 11 volts for Foxconn / Apple to list these values.
            The capacitance - select whatever is available. As noted, there is a cluster of caps on this rail and this cap will not be missed but it is ok to place any capacitance you can find.
            The cluster of caps work together to share the work load (current) on this rail. Also the capacitance of each will add up when in parallel.
            For example,
            https://www.arrow.com/en/products/16tqc47myfb/panasonic
            16TQC47MYFB
            Capacitor Tantalum Polymer
            Cap Tant Polymer 47uF 16VDC B2 CASE 20% (3.5 X 2.8 X 1.9mm) SMD 3528-20 0.09 Ohm 105°C
            • mikay786
              • Aug 2014
              • 765
              Thanks mon2, well at least I can remove and test the board before proceeding further to source a replacement.
              • piernov
                • Jan 2016
                • 4435
                • France
                PPBUS_G3H is 8.6V max on 820-2849.
                • mikay786
                  • Aug 2014
                  • 765
                  Just an update, is all working! Thanks left the cap off as can only buy minimum quantity of 5 for £12 plus seems to be working fine as is.
                  Battery isn’t charging at all, is completely dead with 400mv in it. Shame as only has 65 cycles on it.
                  I was wondering if there was a way to jump it to wake it up? I tried connecting bench power supply to the outer pins on either side of the connector but wasn’t drawing anything. It’s probably got some sort of protection circuitry to stop this? Although i did watch a guy on YouTube jump start his MacBook battery so not sure.
                  • mon2
                    • Dec 2019
                    • 14117
                    Good that the logic board is booting. Battery charging is another case.
                    Proceed carefully to review the charging issue.
                    See attached.
                    Measure and post the voltage reading of the battery connector pins.
                    • artvandalai
                      Where can I get compatible capacitor for replacement?
                      by artvandalai
                      Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
                      12-28-2024, 10:15 AM
                    • Stiffi
                      Macbook Bad capacitor
                      by Stiffi
                      Hello, I have a problem with my MacBook Pro. It doesn't work anymore. I opened it and found that a capacitor was defective. Now the problem is that I can't find it anywhere on the internet. It is a Neo capacitor called "NEX CN7". Where can I buy such a capacitor? I hope someone can help me. Many greetings Stiffi 🙂 A ab22
                      10-05-2024, 03:44 PM
                    • boosti45
                      Macbook pro logic board replacement parts quesion
                      by boosti45
                      i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                      08-21-2024, 05:23 AM
                    • mferna14
                      MacBook Air A2681 battery problem after Screen Replacement
                      by mferna14
                      Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
                      12-06-2024, 08:10 PM
                    • Csfromm
                      MacBook a1990 what capacitor is this?
                      by Csfromm
                      Hello everyone
                      My macbook das not have any backlight at the screen
                      I find out capacitor is broken
                      Can anybody tell me what kind of capacitor is this?...
                      10-17-2024, 08:14 AM
