Macbook Bad capacitor
  • Stiffi
    • Oct 2024
    Hello, I have a problem with my MacBook Pro. It doesn't work anymore. I opened it and found that a capacitor was defective. Now the problem is that I can't find it anywhere on the internet. It is a Neo capacitor called "NEX CN7". Where can I buy such a capacitor? I hope someone can help me. Many greetings Stiffi 🙂 A ab22
  • mon2
    • 14659
    https://www.ifixit.com/Answers/View/...mPjvf5_Z3xDvU6
    Best guess from the limited shared info. Need the model of the macbook; the location of the capacitor; a clear pic of the area where the capacitor used to live.
    • petehall347
      • Jan 2015
      • 4440
      that is a 33uF 20% 16V Tantalum-Poly capacitor in a Case-B3 package.
      • Stiffi
        • Oct 2024
        Yes its a 33uF 20% 16V Tantalum-Poly capacitor in a Case-B3 package.
        But i find no page to buy caps like this.
        Where can i buy caps like this?
        • mon2
          • 14659
          B3 means the cap physical size is 3528 but height is 1.1mm. Check if there is a height restriction on this cap on the logic board. If not, you can use size B tantalum caps here.
          like this one (3528 but taller part):
          https://www.mouser.com/ProductDetail...T3TleiYg%3D%3D
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
          • afarr
            Apple MacBook Pro Mid-2017 A1706 - C7490 Capacitor Help
            by afarr
            Hi all, this is my first post, I offered to check out a friends MacBook Pro, A1706 which doesn't power on, before this happened they smelt something burning inside, and Apple refused to help with out being out of warranty.
            Among investigating a capacitor on the logic board spilt and scorched surrounding area please refer to images; https://imgur.com/a/AmSwFr3
            I found a schematic (x362 MLB Schematic) for the logic board on a thread from this site, I'm unsure about the right terminology when describing so please forgive me.
            On the location I assume...
            02-13-2023, 01:11 PM
          • Csfromm
            MacBook a1990 what capacitor is this?
            by Csfromm
            Hello everyone
            My macbook das not have any backlight at the screen
            I find out capacitor is broken
            Can anybody tell me what kind of capacitor is this?...
            10-17-2024, 08:14 AM
          • envym
            by envym
            Hi everyone!
            06-27-2025, 08:54 AM
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
