Hp 840 g1 6050a2560201-mb-a03
  • dakiza
    • Dec 2015
    • 5
    • serbia
    Hi all, i have a problem with mentioned board. I know that there was a liquid damage on U6600 and U6610 and there was short on 3.3V i have 2.8V and Q6100 was overheating. I change all of mention components and some aditional but no luck. After detail cleaning a have manage to get stable 3.3V and 5V. Now when i connect charger i have only short power LED blink and thats all. And voltage on Q6100 is about 0.87V (lower than needed). I tried to change Q6000, Q6001, U6000, U6200 but is the same. Any hint, what to try?
  • mon2
    • 16800
    Re: Hp 840 g1 6050a2560201-mb-a03
    Start with sheet 5 of the schematic = charger IC @ U6000.
    Review the DCIN mosfets @ Q6010 & Q6011. Often the 2nd mosfet gets damaged.
    Confirm the voltages on each of these mosfets (source ; drain; gate).
    A good idea to also, with great care, measure the voltages on each pin of U6000 charger IC.
    Post your measurements.
    • dakiza
      • Dec 2015
      • 5
      • serbia
      Thanks in advanced. This is measurments:
      Q6010 D - 19.47 S - 19.47 G - 6,12
      Q6011 D - 19.47 S - 19.47 G - 25.6
      And this is the measurment on "good" board (have problem with 3.3 and 5 rails) But have good voltage on Q6100 ~ 1.3V
      • Ayrat Technology
        • Dec 2025
        • 36
        • Bangladesh
        6050a2560201-mb-a03 need boardview
        • mcplslg123
          Hp 450 dead
          by mcplslg123
          MODEL:HP PAVILLION 450
          PCB:INVENTEC HARVEY 6050A2493101
          PROBLEM: TOTAL DEAD, NO DC JACK LIGHT.
          Here is what i've found out.
          01.Q6010-Source 19V,gate-24V,Drain 19V
          02.charging IC BQ24728 measurements:
          ACN/ACP-19V
          cmsrc-19V
          ACDRV-24V
          ACPRES-2.9V(??)
          ACDET-2.62V
          SDA/SCL-3V
          REGN-6V
          R6024 has 3V Pull up ok on one side but on ther side connected to Charging ic's ACOK pin is 2.9V . The resistor is measured out of circuit 10K.
          ADP_ID is ok at 0.58V measured on D6015. Other end of diode...
          10-19-2020, 08:13 AM
        • calledtoconstruct
          HP Envy 15t-as100, No POST, Charging Light comes on, No other visual indicators
          by calledtoconstruct
          Hello All,
          I searched for this Make / Model and did not find an existing thread, however, there were similar threads that were informative.
          In regards to: HP Envy 15t-as100 6050A2857201
          This laptop did power on a couple times, but the video output was jittery / jumpy. At some point, it stopped powering on, with only the charging indicator lighting up. I am able to hold the power button pressed for 30 seconds or so and see the charging indicator cycle (off and then back on again). The battery is drained and likely locked; I doubt it is charging. These observations...
          03-06-2026, 04:32 PM
        • mohamed mm
          HP elightbook 840- g1 battery no present and not charging
          by mohamed mm
          Hi everyone, I hope you are doing well,
          I've HP elightbook 840- g1, it works fine but it's not detecting the battery. I've replaced the battery with new one but same issue not detecting it or charge it.
          the meassurment that I took with adapter on:
          ID volt: 2.6v
          Q6011: 19V
          Q6012: G: 19.5V \\ S: 18.8V \\ D: 0.85V.
          battery pin : 0.95v \\ with battery : 0.32.
          motherboard no: 6050A2560201-MB-A03
          measurement in buzz mode : there is reading between (G and S mosfet Q6012 ( 77.5)), I removed the moseft and measured,...
          02-15-2026, 12:00 PM
        • Elephant Geeks
          HP Elitebook 830 G6 Missing 19V Enable on Q60000&Q60001. What am I not seeing?
          by Elephant Geeks
          Hello, I have both Schema&boardview for 830 G6 (CATALONI 6050A3022401-MB-A01( A1)
          Main power rail 19V is present upto the input of Q60000 high side charger Mosfet. Enable missing on both high&low side mosfets. Beyond that no 19V no 3V no 5V.
          I have noticed that on U6000 which is the charging IC (Intersil ISL9241HRTZ) I only have DCIN 19V ok. VRAVDD 0V, VRADDP 0v, ADP_DET 0V. CSIN 18.55 CSIP 18.12
          I changed the charging ISL IC just incase it was acting up but same result. No corrosion on MB. Tried tracing the VRAVDD to SIO but nothing conclusive.
          What am I missing?...
          01-13-2026, 06:22 AM
        • Bartoloni
          HP ELite Book 840 G1 not charging
          by Bartoloni
          Hi i just received this HP Laptop, the issue is that the power charger is not charging the battery, it show that is on charge, but the % is not increasing...
          customer says also that the laptop is shutting down by itself after a while..
          checking first mosfets i found that Q6011 (RQ3E080BNFU7TB) has a drop voltage of 0V, no diode junction visible, 4 ohms of resistance from gate-source
          surely i will replace it... but i don't have any similar mosfet... and i read somewhere that on this kind of laptop these mosfet after replaced are heating a lot... (and probably is...
          10-19-2021, 07:59 AM
