Macbook pro 15" 2018. keyboard backlight not working
  • wkholi
    • Jun 2021
    • 20
    • Egypt
    Hi. all
    I had to detach my MacBook pro 15 " 2018 (A1990) screen because it was broken.
    The keyboard backlight dies not. work anymore.
    Did I mess something up or the backlight cable is connected. to the screen?
    Thanks in advance
  • mon2
    • Dec 2019
    • 14698
    Re: Macbook pro 15" 2018. keyboard backlight not working
    Can you see the graphics if you use a flashlight / torch along the front face of the display?
    Keyboard caps key light toggles on / off after boot?
    • wkholi
      • Jun 2021
      • 20
      • Egypt
      I Jhabvala completely removed the screen and using an external screen . A new screen is $900
      • wkholi
        • Jun 2021
        • 20
        • Egypt
        The Mac is working better with only one monitor. I had to do that because I was reinstalling macOS and it could not log to the external monitor. So I thought let’s remove the MacBook screen and let the Mac see only one screen ( the external monitor ) and it is working perfectly . Much better when the Mac screen was on . But the only thing is that the keyboard Mack light is not working . Is it related to the screen connector?
        • reformatt
          • Feb 2020
          • 1529
          The previous models use an ambient light sensor in the screen to turn it on/off. Wastes battery if it's daylight, so it's switched off in that case. So with that missing, I'd say that's your issue.
          • wkholi
            • Jun 2021
            • 20
            • Egypt
            Makes sense.
            Probably this is why it is not working.
            But this is a totally different experience, laptop without a screen
            With a big 25” monitor.
            Much better
            I don’t need to be mobile with it any way .
            Thanks for your reply ����
            • reformatt
              • Feb 2020
              • 1529
              You can run a MAC in clamshell mode if the screen is U/S, no need to remove it. Allows you to at least set it up on external monitor, you just need an external USB-C hub that supports HDMI, power pass thru and USB ports etc for keyboard/mouse. You can then set it up in clone display mode, keeping the original display camera if needed.
              • wkholi
                • Jun 2021
                • 20
                • Egypt
                I have been running it like that for a while, but I had to reinstall the macOS and I messed up something on the reinstall process with the hard drive so the Mac would only start in the original monitor mode. I have tried EVERYTHING to try to get the second screen to show to start my new installation and nothing worked ( I realized later that I had the question mark folder).
                So I figured I should disconnect the monitor cable so that the Mac would see only one monitor and be forced to use.
                And it worked 😁
                I spent a few days trying to get it to work .
                The next question, I am trying to find the circuitry responsible for the keyboard backlight so I would try to force the backlight on.
                There must be a pin in a chip in the Mac that is responsible for turning the backlight on.
                If someone knows I would really appreciate it .
                • HTR-Informatique
                  by HTR-Informatique
                  02-09-2025, 06:51 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • frannyjunk
                  Hisense 40H4F no backlight but turns off after splash screen
                  by frannyjunk
                  So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                  TIA.
                  09-24-2025, 10:59 AM
                • turmix
                  AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                  by turmix
                  Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                  The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                  At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                  During another reassembly, I made a mistake, and...
                  01-29-2024, 03:48 AM
