MacBook Air 2018 A1932 820-01521 Not turning on.
  • sikocan
    • Oct 2019
    • 344
    Re: MacBook Air 2018 A1932 820-01521 Not turning on.
    Will do in 30 mins
    • sikocan
      • Oct 2019
      • 344
      Loooong 30 mins... still waiting for client to see if Data is important as this step would wipe the drive.
      • piernov
        • Jan 2016
        • 4435
        • France
        Revive/update keeps data, restore wipes data. In case of corruption or damaged SSD, data could already be gone anyway.
        • sikocan
          • Oct 2019
          • 344
          I can't revive device. It does detect MacBook computer. Here are pictures. If I restore firmware, it'll wipe.
          • duwane
            • Mar 2022
            • 55
            • New Zealand
            What machine are you running the configurator software on? I had something similar with a 1932 that I restored.
            I know that Apple's information gives a minumum version of software of like Catalina or something similar, and says you can use any machine to run configurator on, but I found I needed a machine that had only USB-C ports, and ran the latest patched version of MacOS available for the machine I was using.
            • Arshad alam4659
              • Aug 2020
              • 156
              • India
              #26
              Originally posted by sikocan
              ppbus_g3h 12.268v
              PPDCIN_G3H 5.122v
              I've replaced both caps.
              Hi I have same board and check ppdcin_g3h 20 v
              Need help no power
              • Arshad alam4659
                • Aug 2020
                • 156
                • India
                #27
                Hi I have a same board a1932 if battery and charger connect l7030 heating need
                help
                • mon2
                  • Dec 2019
                  • 14253
                  What is the history of the unit?
                  Inspect the board to see if there is any liquid damage or damaged parts.
                  20v is good for the adapter voltage. Be sure the adapter is the suitable power rating for use on this unit.
                  Measure the voltage to ground of ppbus_g3h.
                  • Arshad alam4659
                    • Aug 2020
                    • 156
                    • India
                    #29
                    Ppbus_g3h 12.19v and and pp3v3_s5 is 3.16v
                    • Arshad alam4659
                      • Aug 2020
                      • 156
                      • India
                      #30
                      Here is one ic is missing
                      • Arshad alam4659
                        • Aug 2020
                        • 156
                        • India
                        #31
                        What is the check if l7030 is heating
                        Someone help me
                        • envym
                          MacBook Pro 2018 with Activation Lock
                          by envym
                          Hi everyone!
                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                          06-27-2025, 08:54 AM
                        • Clarify4082
                          Macbook Air 2018 A1932 Bootloop
                          by Clarify4082
                          I have a A1932 Macbook Air with Bootloop.
                          I already replaced the battery with a new one and reset NVRAM and SNC.
                          When I start the Macbook the Screen is coming on (no Logo) and switches of after a few seconds. If I start without the trackpad and keyboard it stays on longer.
                          If I use diagnostic (Option+D), recovery (Option+R) I always get the Apple logo and it go into online-Recovery. Even if I boot the installer from a USB-stick it ends up in online-recovery. Sometimes it crashed short after entering the wifi password, sometimes it loads the recovery...
                          01-07-2025, 09:41 AM
                        • bouch
                          unlock macbook air A1932 2019
                          by bouch
                          hi
                          i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                          i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                          i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                          have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                          I need help or information?
                          Does anyone have the minat2 activator 1.4 software?
                          Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                          Thank yo...
                          03-12-2025, 10:14 AM
                        • reessi
                          Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                          by reessi
                          With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                          No corrosion any where!
                          Tried a replacement power button off ebay and the same.
                          Very occasionally it will work with the power button connected!
                          Same results with or without the battery.
                          Can it be a fault with the Audio board or the mainboard?
                          The touch Id assembly connects through the Audio board first then to the Mainboard.
                          Flex...
                          06-26-2024, 03:31 PM
                        • mitchw
                          MacBook Air 2018 A1932 820-01521 stuck at 5V, but succesfully does the DFU and boots into OS installer
                          by mitchw
                          I have a 820-01521 that is stuck at 5V, and drawing just 230mA.
                          I did some troubleshooting, and managed to charge the battery up (was at 0%) using a different logic board.
                          Also I ran DFU and it did it successfully. Had to use a PMU_FORCE_DFU jumper to do it.
                          At this point the laptop started up and it successfully boots into the OS Install.
                          The charger is now at 20V, but drawing 0mA, so the laptop is essentially running off the battery. It doesn't detect the charger...
                          I think there could be a problem with one of the CD3215s, but all the LDOs are the...
                          01-04-2024, 01:47 PM
