Dell la-9832p no charging
  • Yosua
    • Jun 2021
    • 221
    • Indonesia
    hi friends, I have a problem with a dell mobo with the code LA-9832P, this mobo can't charge I measured the voltage on the 0v battery pin
    this is the result of measuring ic bq24717
    ACN = 19.6V
    ACP = 22.4V
    CMSRC=22.3V
    ACDRV=28V
    ACOK=2.5V
    ACDET=2.8V
    SRN=15V
    SRP=15V
    REGN=6V
    VCC=21.2V
    I hope someone here can help me
  • mon2
    • 14660
    Re: Dell la-9832p no charging
    Hi. A few comments:
    1) adapter voltage is higher than usual. Should be ~19v.
    Are you using the official power adapter for this logic board?
    2) battery leg is with a good voltage since SRN and SRP are at 15V. Double check your battery contacts. Remove all power and check the resistance from the SRN pin to the battery connector. Should be ~0 ohms.
    3) does the pc work ok other than the battery charging?
    • Yosua
      • Jun 2021
      • 221
      • Indonesia
      Originally posted by mon2
      Hi. A few comments:
      2) For the measurement of srn&srp it is not read in all ohm modes, sir, and does not show 0 ohms
      3) this laptop works fine except the charger sir
      I followed the path of the battery pin connected to the power selector ic sir, what ic is this, and for what?
      • Sephir0th
        • Oct 2020
        • 1289
        Test with known working genuine charger of correct wattage and check your multimeter. Voltages does look indeed to high like mentioned before.
        FairRepair on YouTube
        • Yosua
          • Jun 2021
          • 221
          • Indonesia
          i have tested it with dell original charger, but still no change sir
          • mon2
            • 14660
            In your first post, you measured 15v on srn/srp pins. The same 15v should be reaching the battery connector unless the contact or pcb trace is broken.
            The 15v is a good charging voltage rail but at the same time, the battery connector is at 0volts? Confirm it.
            Remove all power. Measure the resistance from srn to the battery connector. The readings should be 0 ohms. Confirm it again. Maybe some liquid damage in this area? Can you share clear pics of this part of the logic board?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              The reading seems incorrect to me. How ACN/ACP voltage can differ by such huge margin. ACDRV at 28V is too high. I think you need to replace the battery of your DMM.
              • Udemzy
                • May 2017
                • 163
                • Guatemala
                ACN = 19.6V
                ACP = 22.4V
                CMSRC=22.3V
                ACDRV=28V
                ACOK=2.5V
                ACDET=2.8V
                SRN=15V
                SRP=15V
                REGN=6V
                VCC=21.2V
                Since this is a Dell motherboard, first of all connect the display and check if adapter type is ok ,if it shows unknown then PS_ID line is faulty, check for any burnt diode, this is a common fault on the PS_ID line, solve on fault yesterday by removing the burnt diode.
                • Udemzy
                  • May 2017
                  • 163
                  • Guatemala
                  ACP= 19.6v
                  ACN = 22.4v ?
                  There should only be a 0.1v drop between then, check the CLR in ohms mode if it ok.
                  • Yosua
                    • Jun 2021
                    • 221
                    • Indonesia
                    tapi memang pin srn dan srp tidak mengarah ke soket batrai pak, karena aku melihat skemanya
                    but indeed the srn and srp pins don't lead to the battery socket, sir, because I saw the schematic
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • Thomasraud
                      Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                      by Thomasraud
                      i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                      QUOTED
                      -It works on charger (without battery connected-only charger)
                      -It works on battery (without charger connected-only battery)
                      -& it also works when plugged in battery & charger, but it's not charging the battery
                      //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                      and..
                      QUOTE
                      The IC cannot maintain the input current level
                      06-28-2022, 06:47 PM
                    • master3112
                      by master3112
                      07-29-2025, 01:55 PM
                    • Grucha98
                      Dell Latitude E7440 battery not charging only works on AC Adapter LA-9591P
                      by Grucha98
                      Hi, i have problem with dell E7440, battery is not charging. Idk all story. Original Dell Adapter broken up (its not give 19V) i guess first ac adapter broken up and it broken charging circuit in laptop. Laptop has clone battery (Green Cell)
                      Laptop works on clone adapter, and its not charging battery. Like on photo. I checked mosfets near battery plug. They are not shorted. But on PQ809 and PQ810 are low on diode mode (both 0.25V) I desoldered them and check on bench and they are good both 0.5V on diode mode. I checked only drain - source way. So its board circuit it should be higher,...
                      09-09-2024, 11:22 AM
                    • Robocop
                      Dell G3 3579 (LA-F611P) not charging
                      by Robocop
                      Hey guys,
                      I've seen several questions about this exact issue, but I've never found the fix, so I would appreciate if we can start over the whole debugging process again from start to finish, for my specific issue.
                      In the BIOS setup, (see pic) the AC adapter is detected with the correct power rating, the battery is stated as charging (when plugged in, of course), and the battery health is stated as "Excellent" (as expected, since this is a brand new battery purchased a couple of weeks ago). However, the battery never charges (the percentage never increases)....
                      06-25-2024, 08:15 PM
