asus x550vxk touchpad not recognized
  • caprigtx
    • Mar 2022
    • 63
    • Netherlands
    asus x550vxk touchpad not recognized.
    Touchpad is not working at all , even in the bios its not working.
    any one idea,s ???
    • 21861
    Re: asus x550vxk touchpad not recognized
    any one idea,s ???
    Check the ribbon cable for damage,do you have continuity between both connectors.Do you have cntinuity to the EC chip from the pins. Test the resistance also
    • caprigtx
      • Mar 2022
      • 63
      • Netherlands
      Cable is oke , tomorrow i pull the mainbord out.
      • mon2
        • Dec 2019
        • 14662
        Review the voltage on each trackpad connector pin.
        • caprigtx
          • Mar 2022
          • 63
          • Netherlands
          The results
          • Stevedb
            Stevedb
            • Feb 2018
            • 624
            • Belgium
            Flex of connector on picture is not inserted full it must be much deeper. Reseat the flex
            • rheyntau
              ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10
              by rheyntau
              CAN ANY ONE HELP ME WITH THIS PROBLEM....ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10 ..IT WAS ELAN TOUCHPAD..I DOWNLOAD A DRIVER BUT ITS NOT WORKING IT SAYS "WINDOWS FOUND DRIVERS FOR YOUR DEVICE BUT ENCOUNTERED ERROR.....THE HASH FOR THE FILE ISNOT PRESENT INTHE SPECIFIED CATALOG......."
              07-06-2025, 07:22 AM
            • jamesp
              Asus TP412FA keyboard and touchpad not functioning
              by jamesp
              Hello guys,
              need help, i have a laptop that i encountered having keyboard and touchpad not working, not immediately going to BIOS i already tried replacing even just the keyboard with a new one but still problem exists. now i only realized to checked it from bios to erase doubts. i found out both touchpad and keyboard are working only on BIOS but not on windows.
              since i cant just reformat the said laptop, i tried installing MyAsus utility and updated my drivers , and windows update as well. i included updating the bios to latest 3.08 version. still kb and touchpad is working on bios...
              08-18-2024, 11:02 AM
              ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
              This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
              09-07-2024, 02:50 AM
            • ShadowAi
              ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
              by ShadowAi
              Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
              Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
              After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
              03-15-2024, 10:46 AM
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
