MacBook Air 820-3437-b upgrade ram from 4GB to 8GB
  • alfredodinolfo
    • 128
    • N/A
    I would like upgrade ram of 820-3437-b from 4GB to 8GB.
    on board there is "hynix" H9CCNNN8JTAL I have "hynix" H9CCNNNBLTBL.
    this ram Is compatible and is enugh change RAMCFG2 from L to H or i need also bios modified?
    thank you
  • mon2
    • 14021
    Re: MacBook Air 820-3437-b upgrade ram from 4GB to 8GB
    Good question but believe the strapping is all that is needed. Do not know for sure about the bios. We did outsource this service to Malaysia (youtube contact) for an iMAC in the past - they definitely did some strap moves to pimp up the logic board to 16GB. All in all worked well for about a year - then would not power up. We have the unit back and did attempt a proper reflow of the memory ICs with our BGA workstation but still no luck to allow for the proper boot.
    For us, on the imac - led #1 and #2 are now solid ON but no other. led # 3 = MEMORY for this A1419 unit. Work for another day...
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
    • kuba2102
      Macbook Air M2 A2681 NAND upgrade error 35
      by kuba2102
      Hello people. I have undertaken an upgrade from 256GB to 512GB. I have another A2681 board that I sourced NANDs, resistors and capacitors from. Yet when I try to restore the firmware in FDU mode I get the error 0x23 (35) (error formatting the NAND). Could it be the faulty NAND or I have missed something? Thank you...
      07-03-2025, 12:20 PM
    • tobeend
      Bypass mdm macbook m2 ventura
      by tobeend
      1. RESET MACOS WITH IPSW
      a. Power off MacBook, press and hold the power button to enter Recovery
      b. Open Disk Utility, remove Macintosh HD
      c. Reboot, connect to the network to Activate Mac.
      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
      e. Release the other keys, but keep holding the Power key for another 10 seconds
      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
      05-26-2023, 07:18 AM
    • Logix_UK
      MacBook Pro A2338 SSD Upgrade problems
      by Logix_UK
      Hi Everyone, I have a MBP A2338. It had 256Gb Storage, I bought new Nands on Ali and I have installed them, today. After re assembly I booted the Mac in DFU and revived it with Apple Configurator. It got to step 3 and the Mac hung. I was forced to hard boot it and it will not boot into DFU now. I am using the top USB-C port, I have a USB-C data cable and I have tried DFU Blaster, in trial mode, and I can not get it to boot into DFU now. I am getting 5V and just a few milliamps. Can anyone think of anything?
      Thank you...
      05-10-2025, 02:41 PM
    • SarcasticOP
      General question about MacBook power rails for repair.
      by SarcasticOP
      I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
      • PPBUS_G3H (12.6V-12.8V)
        • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
      • PP3V42_G3H (3.42V)
        • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
      • PPVRTC_G3H (3.3V)
        • This
      12-12-2024, 05:50 PM
