Asus P2520L dead motherboard
  • Badcop79
    • Jul 2022
    • 5
    • Italia
    I need help.. My Asus P2520 (motherboard P552LA-LJ) won't power on. After plugin charger, PD8103 and the on the other side PU8101 are very hot.
    I check some point on repair guide and:
    "17 PSL8103 +12VSUS 1483" I have 0V
    "3.PSL8100 +3VAO 460" I have 3V
    "7. PSL8102 +3VADSW_ON 567" 0V
    "2.PSL8101 +5VAO 503" 0V
    Can anyone help me?
    Thank you
    P.s. sorry for my english....
    • 21899
    Re: Asus P2520L dead motherboard
    5VAO is an always on voltage. Remove all power and post resistance to ground measurements for PSL8101 .Do you have a boardview, and do you have a DC lab power supply
    • Badcop79
      • Jul 2022
      • 5
      • Italia
      psl8101 is not in short to ground
      I have boardview but don'tha dc lab power supply at the moment...
        • 21899
        Boardview https://www.badcaps.net/forum/showth...ghlight=P552LA
        Desolder PD8103 then find PU8101 ,attach power and check if its still hot
        • Badcop79
          • Jul 2022
          • 5
          • Italia
          pu8101 is still hot
            • 21899
            Originally posted by Badcop79
            pu8101 is still hot
            ok replace pu8101
            • Badcop79
              • Jul 2022
              • 5
              • Italia
              ok i will try!
              I want replace also pd8103 can you tell me what componente is it? On the surface there ia code "L44" but can't find anything on internet.
              Thank you
              • dhenion
                Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                by dhenion
                I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                The original board was:
                ASUS X510UNR REV 3.0 A
                The replacement board is:
                ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                01-30-2024, 01:45 PM
                ASUS P5GC-MX motherboard recap
                by momaka
                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                So here is what the motherboard looked like with its original caps:
                CPU VRM area up close…...
                01-27-2021, 11:59 PM
              • SavaBogdan
                Dead ASUS ROG STRIX X299-E Gaming Motherboard
                by SavaBogdan
                Hello. I am having some trouble with a X299 motherboard. I did some searches and I found very little info about these X299 chipset motherboards. It's a bit strange because they are known to be unreliable and I expected to find lots of posts. So I decided to make a thread and ask the experts for help
                Ok, here is the info I have.
                The board is completely dead, nothing happens when I try to start it up.
                I stripped it down and started measuring. I have 3.3v on the power on switch pin, so that is ok. I also found 1v on a coil near the sata ports and 3.3v on the coil next to the...
                04-03-2023, 08:07 AM
              • MakNCheese
                ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                by MakNCheese
                I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                Symptoms:
                • Severe lag across the system, including BIOS navigation.
                • Slow boot times and unresponsive performance in Windows.
                • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                • No error messages or BSODs, just extreme sluggishness.
                What I've Tried:
                • Replaced
                06-04-2025, 12:48 AM
              • EvazX
                ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                by EvazX
                I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                However, after some time, the replacement motherboard...
                08-25-2025, 06:09 PM
