alienware m11x r3 battery power on problems
  • armands0212@gmail.com
    • Oct 2021
    • 28
    • Latvia
    hello everybody.have a problem with m11x,it wont power on only on battery(only flash lights and off) if keep pressing on button after few attempts it not even flash lights and cant start it from psu as well so only solution is disconnect battery and reconnect it and then starts ok with power supply.
    if laptop is started with power supply than everything works ok and can disconnect it from power and it runs from battery just fine,so something not letting it start laptop on battery power i guess
    updated bios and all drivers and same
    battery is ok itself as well as have one more m11x and m14x to test it and on both battery runs perfect
    any ideas what is the problem?
    thanks
    • Oct 2021
    • 28
    • Latvia
    Re: alienware m11x r3 battery power on problems
    oh yes and it powers on from battery if powered back on straight after shutdown,but after some while off it wont power on...
    • mon2
      • Dec 2019
      • 14666
      The mosfets mated with the charger IC need to be reviewed. While they are passing through the voltage to the logic board, you likely have defective mosfets.
      Start with, remove all power / no battery.
      Meter in resistance mode.
      Measure the resistance of each of the 2 x dcin mosfets as follows:
      Source (1-2-3) & drain (5-6-7-8)
      Source (1-2-3) & gate (4)
      Gate (4) & drain (5-6-7-8)
      Post each measurement and the meter scale used.
      Repeat for the next mosfet.
      You will find 3 other mosfets that will be for the battery charging and that connects the battery to the logic board.
      Also interested in the measurements of those mosfets which are high side, low side and battery mosfets.
      One or more of these is leaking. The measurements will tell us which one is defective.
      No power when checking the resistance values.
      ps: see a number of different logic boards for your model so just picked one but the idea of testing is the same. You should see 2 x mosfets near the dc adapter connector -> start there. NO POWER -> RESISTANCE checks on the pins.
        • Oct 2021
        • 28
        • Latvia
        Hi Mon2.Thanks for quick response and nice detailed explaining .i didnt have time today to get back to it but i will spend some proper time on it when my shift at work finishes.thanks again for reply and i will update how it goes as soon as i get to it
          • Oct 2021
          • 28
          • Latvia
          ok turned out it was just faulty rtc battery what was causing troubles to start laptop from battery.alienwares and they little tricks sometimes can surprise
          • mkdj
            ASUS X571 no power : battery issue?
            by mkdj
            Mark and model: ASUS X571
            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
            Tests already made:
            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
            - I have removed...
            07-14-2025, 09:16 AM
          • DenK
            Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
            by DenK
            Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
            1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
            12-06-2024, 01:29 AM
          • Gust zhang
            Mid 2014 A1398 MacBookPro,Is it feasible to remove the battery from the MBP and connect it to an external power supply?
            by Gust zhang
            ​I have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
            02-16-2025, 08:39 AM
          • survivalbloke
            Acer Predator Helios 300 - will not power up if battery is CONNECTED
            by survivalbloke
            This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
            06-25-2025, 12:20 PM
