Asus X756 no power.
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Asus X756 no power.
    Hello friends
    Got this motherboard that don't power on. Asus X756UXM.
    Power consumption stay at 0.02 amp before/after trigging.
    No short to ground at all coil.
    3/5v alwys are present.
    No shematics/brd...SIO- ene KB9026Q C so i use this brd from another asus to measure io requirements.
    https://www.badcaps.net/forum/showthread.php?t=85968
    +3VA_EC = 3v
    EC_RST# = 3v
    PM_PWRBTN# = 3v
    PM_RSMRST# = 0v !
    PWR_SW# = 3/0/3
    I try another bios ;ver 311 for X756UXK as mention at the ticket at ram socket but same issue.
    So what to check else!!
  • mon2
    • 14677
    Re: sus X756 no power.
    Start with the dcin mosfets and the charger IC.
    Remove all power, meter in resistance mode.
    Check the usual mosfet measurements to confirm the dcin mosfets are not defective.
    Source & drain
    Source & gate
    Gate & drain
    Post each resistance value and also the scale used on your meter.
    • lapfix
      • Mar 2020
      • 2764
      • my workshop
      Hello my friend
      Scale used : MOHM...other scale got nothing ( Kohm and Ohm )
      Acfet :
      Source & drain = 02.82mohm
      Source & gate = 03.11mohm
      Gate & drain = 01.05mohm
      Rbfet :
      Source & drain = 01.17ohm
      Source & gate = 03.19mohm
      Gate & drain = 04.55mohm
      Charger IC = BQ24780S
      pin 5 = acok = 3v
      pin 6 = acdet = 2.67v
      pin 24 = regn = 6v
      pin 28 = vcc = 19v
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        What is the resistance on RSMRST#?? Should be measured without any power source and should be 10K or higher.
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          [QUOTE=lapfix;1150502
          Rbfet :
          Source & drain = 01.17ohm...not ohm but kohm
          [/QUOTE]
          Thank you mcplslg ...10.1kohm ..question : in asus motherboard no need to program io !!
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • ShadowAi
            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
            by ShadowAi
            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
            03-15-2024, 10:46 AM
          • meraklinetx
            Asus Z97-a power cycle, no boot no cpu voltage
            by meraklinetx
            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
            05-10-2023, 06:08 AM
