Laptop Screen top part working bottom part all white
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys, I have an old laptop here I'm just trying to fix for the fun of it really
    The top part, maybe 25% or 33% of the screen display works, (DOS boot text or bios screen, I have no HDD fitted) but the bottom part is all white.
    On an external monitor connected to the VGA the picture is good.
    So basically I have a horizontal division, below which the screen is all white. There is no apparent damage to the screen or any vertical lines
    I tried cleaning the pins on the LVDS connector plug/socket as thy looked a bit dirty (18 pins plus ground) but it did not help
    On the screen TCON board is an eprom S-24CS02A which I assume is the EDID data or something like that. This is compatible with my TL866 programmer so I could remove it and read/write to it if I want to.
    Is this type of fault possibly caused by a corrupted eprom or other problem on the TCON board or is it always a faulty LCD panel itself?
    If it is eprom, where can I find a suitable file to write?
    See pics for all the numbers marked on the LCD panel. Airis LM13W
    best regards
    Richard
    Follow me on YouTube
    Learn Electronics Repair
  • mon2
    • Dec 2019
    • 14679
    Re: Laptop Screen top part working bottom part all white
    Post a picture of the actual display in action while it is not working as described.
    • piernov
      • Jan 2016
      • 4439
      • France
      Probably column drivers not receiving the bias voltages due to a break somewhere. Comparing the voltages on the test pads on the column driver tab that works with the ones that don't may help figuring out the problem. Then it's possible to jump the missing rail, assuming that's the only problem. Even if that fixes it, the panel cannot be considered reliable anymore.
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        @mon2
        I can do that tomorrow. The bottom 3/4 or 2/3 are just plain white when viewed directly straight on and have some greyish lines in them when viewed at a wide angle. The top area looks perfect all the way across the screen when in the BIOS or on DOS load screen - I don't have HDD attached. There is a sudden point below it goes from a good picture to all white, like for example if someone had placed a piece of white A4 paper over the bottom portion of the screen - just like in this image (not mine, and mine is like 1/4 OK and 3/4 white, not half and half)
        https://ccm.net/forum/affich-963190-...creen-is-white
        @piernov where is the 'column driver tab'? Wouldn't a problem with column driver cause vertical lines or vertical area of the screen to not work? Just based on the fact that columns (in architecture at least ) tend to be tall vertical things
        • piernov
          • Jan 2016
          • 4439
          • France
          Yes my bad, I meant row drivers. Panel need to be partially disassembled as the tabs are behind the metal frame, on the side of the panel. (some panels don't have them at all, may be driven directly from the row drivers, not sure)
          The column drivers would cause vertical bands instead, they are on top between the PCB and the actual LCD, seen in your last picture. Row drivers look the same but there's only one side connected.
            • 21971
            here https://www.badcaps.net/forum/showpo...6&postcount=81
            Airis LM13W
            The motherboard is made by FIC ,here`s a schematic in case you run into some other problems
            https://www.badcaps.net/forum/showpo...62&postcount=1
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              Due to some misadventure I no longer have the eprom chip and Aliexpress don't appear to have S24CS02A
              Is there some equivalent I could use?
              • mon2
                • Dec 2019
                • 14679
                Use the Atmel AT24C02 here. The original is nothing special...just a standard I2C bus 5 volt eeprom.
                • harp
                  White screen repairs
                  by harp
                  To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                  Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                  On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                  05-13-2024, 03:43 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • EazyBone
                  Sharp LC-65Q620U White Screen
                  by EazyBone
                  Another TV topic!!
                  I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                  The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                  Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                  08-21-2024, 12:56 PM
                • hcinne
                  Dell G15 ryzen edition black screen 2 amber 1 white
                  by hcinne
                  I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                  07-23-2024, 07:56 AM
                • Chrissygizmo
                  Panasonic TX-48CX350B backlights but white screen , blank screen
                  by Chrissygizmo
                  Hi all, I’ve got a problem I hope someone can help me fixi.
                  I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                  01-11-2025, 03:18 PM
